Newb Zeitronix Question
Old Jan 24, 2007 | 08:19 AM
nj1266's Avatar
Originally Posted by jfitzpat
Technically, I think it would be $224 (isn't EvoScan $25?). But LogWorks, which we distribute free, will do MUT logging from the ECU. So someone may not need to make the EvoScan investment.
-jjf
Plus you get all the freaking guages that you want. These are the ones that I use while driving.
Old Jan 27, 2007 | 04:53 PM
EVOBrad's Avatar
Hello Zeitronix, do you plan to create matching standalone 52mm gauges for EGT and Boost as well? (Nice work on the new AFR gauge - I'm going to order one as soon as they're available!)
Old Mar 9, 2007 | 04:16 PM
DJ Brett B's Avatar
So... I'm a little confused about this Zeitronix gauge... I have a few questions about it, and I am interested in it as an alternative to UEGO just to moniter A/F and EGT while running meth
1) Do you NEED to run zt-2 with the gauge?
2) Can this be used to moniter a/f just like the AEM UEGO? (for somebody who isnt concerned about data logging)... it looks much better than the UEGO and will match the DDS3 nicely!
Old Mar 9, 2007 | 04:25 PM
kreionic's Avatar
Not sure if the gauge will read out egt
1 yes
2 yes
Old Mar 9, 2007 | 04:28 PM
FastAzzEvo's Avatar
Originally Posted by ShamelessCookie
Question...
I will at some point be getting a Wideband... Most agree that the Zeitronix is the top of the line.
I'm waiting for this to become available:
So my question is, what exactly do I have to buy? Do I buy a ZT2 and then connect this 52mm gauge to it? Do I need more than just the ZT2? Where's the best place to get all this?
All I'm looking for is AFR via the new 52mm gauge, and I wanna spend the least I can to get it.
Thanks, in advance.
You would have to buy the zt2 and the gauge in order to log, but I am not sure if the gauge comes with a wideband. I'm pretty sure it taps into the zt2 box.
Old Mar 9, 2007 | 05:45 PM
DJ Brett B's Avatar
They call it a wideband afr gauge.... says it plugs directly into the zt2, but I'm still not sure if it NEEDS the zt2, or if it can work independently as a wideband like the UEGO without having to use zt2... here is more info on it:
http://www.zeitronix.com/index.html
BTW I am looking mainly to use this gauge as just a wideband as an alternative to the UEGO for now... and then maybe down the road add the zt2 (if possible, and rather than buy all at once)... unless its necessary to purchase the zt2 in order to run this gauge. I am new to wideband and dont plan on datalogging, just want a wideband avoid running to lean after I install the Aquamist HFS-5 WI/meth kit.
Old Mar 9, 2007 | 08:28 PM
EVOBrad's Avatar
I'm pretty sure you need the ZT2.
Old Mar 10, 2007 | 06:39 AM
DJ Brett B's Avatar
yeah probably right. oh well, guess I'll have to learn how to data log
buffhulk
Jun 22, 2017 04:39 PM
stefenboy
May 20, 2016 07:51 PM
Blak94GSX
Evo X How Tos / Installations
21
Feb 4, 2015 03:02 PM
_des_
For Sale - Miscellaneous Automotive
Aug 26, 2011 12:32 PM
SRTRaceR04
Dec 25, 2006 09:44 PM
