step by step to 2 byte
Old Feb 3, 2007 | 01:55 PM
coolguycooz's Avatar
ok so we have all seen the thread that was talking about the 2 byte load, to know exactly what load cell the ECU is in.
Now can somebody post up a step by step on exactly what you have to do to get it to work with evoscan?
also what are the possibilities that it will be a logable variable in future versions of evoscan or mitsulogger.
Old Feb 3, 2007 | 06:34 PM
MalibuJack's Avatar
Both Evoscan and Mitsulogger can log the values from 2 byte load easily with its current method. I know Mitsulogger can log the proposed 2 and 3 byte responses if the guys making mods decide to do it.
This actually has been documented before in another thread, I just can't find it at the moment.
Old Feb 3, 2007 | 08:45 PM
jfitzpat's Avatar
FWIW, same with the CableTools control I wrote (and use in the LogWorks MUT plug-in). Info on methods courtesy of MJ...
-jjf
Old Feb 4, 2007 | 06:14 AM
chrisw's Avatar
https://www.evolutionm.net/forums/sh...ight=byte+load
searching is your friend.
WARNING... this is an advanced topic, don't try it unless you understand what you are doing.
iXac
Feb 10, 2012 07:05 AM
crewdawg130
Jun 3, 2008 12:52 PM
racer135
Apr 17, 2008 06:36 AM
kkarim
Nov 26, 2007 06:51 PM
