What is the purpose of using 2 byte?
Old Apr 16, 2008 | 05:33 AM
racer135's Avatar
What is the purpose of the 2 byte thing? Is it just better resolution from using 2 byte vs 1? Is the 2 byte load the same as the LoadCalc that EvoScan logs?
Old Apr 16, 2008 | 06:07 AM
tephra's Avatar
2byte = twice as much data
loadcalc != 2byte load... its close thou
Old Apr 16, 2008 | 06:14 AM
racer135's Avatar
If loadcalc is not the same as the 2byte load. Then what is 2byte load? What’s the use for it? Why do people log that?
Mr. Evo IX's Avatar
2byte load is the actual ECU Load that is being looked up by the ECU. Load calc is an estimate of where the ECU should be looking. Or at least that's what I've gathered.
In other words, 2byte load is more accurate.
Old Apr 16, 2008 | 07:11 AM
tephra's Avatar
loadcalc is a best guess that ML or Evoscan makes based upon other things
2byte load is what the ECU is actually using to look up timing/fuel maps
Old Apr 16, 2008 | 08:20 AM
racer135's Avatar
Ok. If I make the changes for the 2 byte load will a tuner that uses ECUTak be able to read and flash my modified ROM? OR will it screw up things?
Old Apr 16, 2008 | 08:25 AM
Evoryder's Avatar
The program they use to read your logs should support 2byte load...that should be a minimum for a "tuner"
What program are you using to change your ecu settings? Ecuflash I assume?
Old Apr 16, 2008 | 08:47 AM
mrfred's Avatar
It won't screw anything up. They will not even know that you've made the change unless you tell them.
Old Apr 16, 2008 | 10:09 AM
racer135's Avatar
Yes, I use ECU Flash but the tuner will use EcuTek for tunning. Does that mean that EvoScan does not read all the parameters that an aftermarket logger reads? Is that also true with EcuFlash? Will EcuTek has access to more tables for tunning?
Old Apr 16, 2008 | 10:31 AM
mrfred's Avatar
I have not seen the ECUTek setup for an Evo 8/9, but based on what I have seen in ECUTek flashed ROMs, ECUFlash now has more tables than ECUTek.
EvoScan is an aftermarket logger. I think all loggers except the Mitsubishi MUT diagnostics utility are considered aftermarket loggers. Not sure what logging capabilities ECUTek has. Can't be any better than what EvoScan can do when EvoScan is combined with the ability to modify the MUT tables with ECUFlash to make virtually any parameter used by the ECU available for logging.
Old Apr 16, 2008 | 04:52 PM
tephra's Avatar
get a real tune - ecutek is too much $$$'s
Old Apr 16, 2008 | 07:21 PM
sub7's Avatar
I guess my input would be 2byte load allow you to run map tracer (from Evoscan) to plot your load and rpm base on knock/afr/timing while Loadcalc don't.
Old Apr 16, 2008 | 07:34 PM
tephra's Avatar
nah its just about accuracy.
2byte is better because that's what the ECU uses.
loadcalc is just a guess - but its pretty good... log both side by side
Old Apr 17, 2008 | 04:02 AM
racer135's Avatar
To do the byte load in EcuFlash I need to modify the xml file right? I do not need to Flash the ECU for that right? What about EvoScan do I need to modify any file in EvoScan to run the MapTracer (BTW what is maptracer?) in EvoScan?
Old Apr 17, 2008 | 06:36 AM
mrfred's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=261465
https://www.evolutionm.net/forums/sh...d.php?t=327185
Read read read
kartectuning
Jun 14, 2012 08:01 PM
Seijuro
Mar 20, 2010 11:53 AM
lemmonhead
Jun 27, 2009 07:51 PM
mchuang
Feb 24, 2008 11:00 AM
NIevo
Sep 21, 2007 07:11 PM
