MITSULOGGER ERROR hex file
Old Apr 16, 2008 | 04:53 PM
EVOVIII200's Avatar
need a little help, i keep getting the an error when i try to open my stock rom.hex file, it reads" image file is incorrect size". any help is appeciated
Old Apr 17, 2008 | 04:27 AM
MalibuJack's Avatar
Probably because Mitsulogger doesn't open ROMs, your thinking about ECUFlash.
Old Apr 17, 2008 | 07:01 AM
EVOVIII200's Avatar
thanks for the response malibu, i am trying to get a data log saved. ECUflash does its job but when you save the file of your stock rom. there is and error. how do you get mitsulogger to read and save a file so that ECUflash can read it when i reopen the file.I don't have Evoscan, i am already using mitsulogger i just need to save data and read it
Old Apr 17, 2008 | 07:09 AM
Tuner@Swift's Avatar
ECU Flash doesn't read log files. You need Data Log Lab or Excel to read the .csv files created by mitsulogger.
Old Apr 17, 2008 | 07:17 AM
EVOVIII200's Avatar
ok thanks, does exel convert hex file to.csv file and how was you able to save your data log file using mitsulogger
Old Apr 17, 2008 | 07:20 AM
Alright, stop confusing your ECU image or ROM with a log file. ECU flash deals with files with the extension of .hex. These are images of your ECU that are read, written and edited within ECU Flash. Mitsulogger logs requested engine parameters and are saved as .csv files. These 2 files are completely different.
Old Apr 17, 2008 | 07:30 AM
EVOVIII200's Avatar
got that .where does the .csv file save when stop logging.
Old Apr 17, 2008 | 07:34 AM
Default, I believe, is in the same directory as mitsulogger.exe.
Old Apr 17, 2008 | 07:37 AM
EVOVIII200's Avatar
thank you matt i am good to go. i saw the file in the exe file. you are the shizzle! i might get banned for saying that.
Old Apr 17, 2008 | 07:38 AM
Not a problem dude. If you have any questions interpreting your logs, feel free to ask us.
Old Apr 17, 2008 | 07:41 AM
EvoBroMA's Avatar
this is just painful to read...
Evoscan and Mitsulogger are logging applications... they record data while your running your car to a log file (.csv, .txt) that you can later analyze in the application of your choice - ie: Data Log Lab, Excel, Logworks etc.
ECUFlash is a ROM editor, as well as it can read and write to your cars ECU. This is what you use to make changes to your ECU, and it Edits rom files (.HEX .BIN .ROM)
good luck!
EVO(boss)
Mar 27, 2017 08:40 PM
StarWolf
May 27, 2016 08:39 PM
StarWolf
Jan 11, 2016 07:20 AM
Jhova5
AEM EMS
Nov 14, 2015 10:43 PM
jrsimon27
Nov 3, 2012 05:15 PM
