tephra mod 7 logging load
Old Jun 13, 2012 | 07:46 PM
kartectuning's Avatar
How to proper log load on such a big map?
I am running 30 psi and losing fuel/timing map logging resolution from 2byte and 1 byte load data, using the stock evo 9 maf on a gtx35 turbo
what is the easiest route to chase and log the load to super precise!
cheers
Old Jun 13, 2012 | 07:51 PM
Benja's Avatar
Log 1byte.
Only log the bare minimum to gain maximum resolution.
You should be able to put a pretty good picture together with logging TPS/RPM/1bLoad/Wideband/Knock/Timing
Old Jun 13, 2012 | 09:45 PM
stunt2's Avatar
I think he means that it max out V7's 350 load map ?
would like to hear the solution of this as well
Old Jun 13, 2012 | 10:17 PM
Benja's Avatar
Ok, well log the load you're hitting.
Then re-scale the maps 20 load above the peak load you're seeing.
You may need to scale it in the manner than everything in the 200's jumps by 20's, and above 300 jumps by 10 to give you the necessary resolution at that boost.
Old Jun 14, 2012 | 12:05 AM
stunt2's Avatar
is it a bad idea to rescale sub 100 load area by 20 instead of 10 ? is there high resolution needed below 100 load ?
Old Jun 14, 2012 | 08:01 PM
Benja's Avatar
10-40 is ok in most cases as that's idle. I would leave 40-100 in 10's to allow resolution of cruise and transition tuning, particularly timing.
W2J
May 16, 2011 03:27 PM
Seijuro
Mar 20, 2010 11:53 AM
lemmonhead
Jun 27, 2009 07:51 PM
andrewzaragoza
Feb 18, 2008 06:28 PM
NIevo
Sep 21, 2007 07:11 PM
