help in using 2-byte load with maptracer.
Old Jan 22, 2008 | 01:33 PM
andrewzaragoza's Avatar
i'm starting to tune my car. i was able to successfully do the 2-byte load mod and try logging it with mitsulogger. i was testing around the maptracer on to help me out modify the correct cells but how do it modify it to make use of the 2-byte load that i am logging.
Old Feb 18, 2008 | 05:30 PM
bump
Old Feb 18, 2008 | 05:32 PM
kreionic's Avatar
2 byte load is for us logging. The ecu already uses 2 byte. We do the mod to the rom so we can actually see what the load is instead of going by a calculation. Actually the ecu uses i believe 2 or 3 different loads for different things but 2 byte is close enough
Old Feb 18, 2008 | 06:06 PM
Jack_of_Trades's Avatar
Are you asking how to view the 2 byte load in map tracer?
Old Feb 18, 2008 | 06:27 PM
^yes. how will map tracer make use of the 2 byte load that i am logging.
Old Feb 18, 2008 | 06:28 PM
Its just way more accurate, just check the 2-byte load box instead of the loadcalc box. Then you'll know exactle which load cells to adjust for timing or fuel. Its that easy.
yeah i just wanted to make use of map tracer to help me identify which cells im hitting.
roni4g63
Nov 14, 2015 11:45 AM
criptballer
May 8, 2011 04:50 PM
chmodlf
Aug 24, 2008 01:17 PM
racer135
Apr 17, 2008 06:36 AM
lapulapu
Jan 27, 2008 08:51 PM
