Tutorial: How to scale your MAF [pics]
Old Dec 13, 2009 | 09:05 PM
  #151
D-VO's Avatar
Originally Posted by TJung
Thanks a lot. This forum knows everything
And one more thing: Can anyone tell me, where could I found the MAF Scaling table .xml patch for 88590015 ? Is the table "MAF scaling" in this ROM the same that "AirFlow/HZ RAW scaling" ?
I haven't heard of a patch for the MAF. Really all I've seen were scaling mods.
The MAF scaling and AirFlow/HZ RAW tables are the same, just re-named and are using a different x axis scalings.
BTW: You should be tuning the "MAF Compensation" table not the "MAF scaling".
Last edited by D-VO; Jul 28, 2010 at 08:59 PM. Reason: I don't know what i was on when I wrote this
Old Jul 28, 2010 | 11:52 AM
  #152
adcgn45's Avatar
i have a stupid question but before i bother messing with this but if the ltft number is negative then (-8) then the values need to go up in the map correct?
Old Jul 28, 2010 | 12:52 PM
  #153
fostytou's Avatar
EvoM Community Team
False
Old Jul 28, 2010 | 02:52 PM
  #154
adcgn45's Avatar
ok so they go down
Old Jul 3, 2011 | 08:22 AM
  #155
goodhart's Avatar
Anyway we can get the pictures from post #1 back or is this thread now outdated by a newer one?
Old Jul 3, 2011 | 10:15 AM
  #156
03lances's Avatar
ok so they go down
Correct. If its reading -8 that means the ecu is using the trim to pull that much fuel out so to help get that number back up to zero (or close) you just have to take some fuel out yourself so the ecu doesnt have to.
Old Jul 3, 2011 | 02:37 PM
  #157
project_skyline's Avatar
This thread is so outdated I wouldn't even bother using it.
Old Oct 7, 2011 | 10:39 AM
  #158
NOMIEZVR4's Avatar
Pic's not working
Does anyone have the pics for this?
Old Nov 1, 2011 | 08:15 AM
  #159
jonmorera's Avatar
From: Costa Rica with business addres in Miami FL 33166
I want to learn how to rescale the maf, someone update the pics on this thread please.
Old Nov 1, 2011 | 08:21 AM
  #160
jonmorera's Avatar
Originally Posted by NOMIEZVR4
Pic's not working
finally found the doc, I hope to help you.
https://www.evolutionm.net/forums/5965619-post107.html
Old Nov 1, 2011 | 01:12 PM
  #161
chetrickerman's Avatar
Veteran: Army
good find
Old Nov 2, 2011 | 10:46 AM
  #162
PrimerSdime's Avatar
Thanks, I was also curious about this thread.
Old Jan 2, 2013 | 05:22 AM
  #163
jameswwt's Avatar
Great Info...
Just wonder does this steps on adjusting the MAF Scaling applies same to Evo's 4 5 6 and say if my Trims is within +/- 4 do i still need to adjust my MAF Scale?
Ive a 4" s/s pipe turbo compressor inlet, 2.5" i/c all round and 3" i/c on the bov til throttle body.
Im still finding a way to resolve my buck/super rich afr whenever i immediate full throttle.
Will get another MAF sensor tomoro and hoping for the best or i still need to adjust my maf scaling?
Gt3076r
S2 cams
575x600x50mm I/C
Old Jan 24, 2013 | 06:12 PM
  #164
CRONZ305's Avatar
how does this apply to MAF Compensation because that is the table i have i dont have MAF Scaling
Old May 29, 2013 | 07:49 PM
  #165
Kakihara's Avatar
oops wrong thread it was a 2byte airflow question
