Maximum Timing Advance: IX
Old Feb 19, 2007 | 03:34 PM
Ralph's Avatar
Question Maximum Timing Advance: IX
Yes, I searched. This question is for IX's only, as VIII's run higher timing.
So the questions I have is..
If I were using race gas and could increase ignition timing higher and higher with each pull.. even if i were getting 0 knock the whole time, when should I stop messing with timing?
What should be an absolute peak timing advance before I should think, maybe its time for an increase in boost instead, lean out AFR's .. etc.. (btw redline @ 7800 RPM)?
Information: No AWD dyno available, so I can't find MBT that way..
Thanks
Old Feb 20, 2007 | 09:21 AM
Ralph's Avatar
Come on, anybody ?
Old Feb 20, 2007 | 03:32 PM
JohnBradley's Avatar
Boost
Fuel
Spark
Timing stops with knock, then dial back a degree or 2.
Example---
30psi
11.9 AFR
15* (it knocked at 17 so back it down)
Timing falls where the engine is happy if you have your other variables where you want them.
This one of many ways to do it. I cant say that there is a wrong or right way, becuase if done based on knock you will always have the highest cylinder pressure for a given combo that you can and therefore the highest torque for a given rpm. Boost and octane are always the 2 variables to consider first. The next one is preference, unless you calculate the difference in specific gravity of the fuel and know for a fact that XXX octane requires YY.Y AFR, then timing.
Old Feb 20, 2007 | 03:37 PM
Ralph's Avatar
I guess its time to up the boost then..
Old Feb 21, 2007 | 09:19 AM
EVOB23's Avatar
I would of started by pulling up the boost if your on race gas then add timing form there.
itsmeek
Feb 9, 2016 02:50 PM
bishiboy
70
May 10, 2014 09:54 PM
Sugarj
16
Aug 1, 2012 08:09 AM
trinydex
26
Oct 13, 2007 01:16 PM
Lancer EVO IX
Dec 16, 2005 09:21 AM
