changes to ecu map
Old Feb 20, 2007 | 02:23 PM
FastAzzEvo's Avatar
changes to ecu map
I was looking at my flashed ecu map and a stock ecu map and was wondering how I can tell the difference in the changes. Particularly the boost and fuel settings.
I'll load up screen shots of the two if needed.
Any help is appreciated.
Old Feb 20, 2007 | 02:54 PM
AMSTuning.com's Avatar
Not sure what you are asking. There aren't any "boost changes" you can check your boost limit and duty cycles if they were indeed changed. Open ECUFLASH software, load the stock map, load the flashed map, go down to each parameter box and compare each map, the changes in the fuel and timing will be very apparent.
Old Feb 20, 2007 | 03:47 PM
FastAzzEvo's Avatar
okay thanks.
There are slight differences my wastegate max duty cyles 1,2,3, or lower percentages than that from a stock ecu's and my fuel map is leaner slightly in places.
