Boost/evoscan/boost gauge
Old Feb 22, 2007 | 12:09 PM
jordo's Avatar
My car is completely stock. I recently installed a greddy boost gauge.
i tapped the intake manifold vacuum line that connects to the bov.
For some reason it keep saying im boost 30psi.
When i run a evoscan i get 329kpa..
I have no idea whats going on..
Old Feb 22, 2007 | 12:31 PM
jordo's Avatar
Is it possible for maybe something defective with my wastegate or boost solenoid or something?
Old Feb 22, 2007 | 12:47 PM
C6C6CH3vo's Avatar
A defective WG, sol, or something is unlikely to produce 30 psig
Guage must be bad unless you accidently tapped into the fuel line
Old Feb 22, 2007 | 01:02 PM
jordo's Avatar
Its tapped off the center line on the intake manifold that goes into the hard line for the bov..
Old Feb 22, 2007 | 01:06 PM
C6C6CH3vo's Avatar
Thats the ideal place - shouldn't be more than 15" in Hg or 20psi if stock
Old Feb 22, 2007 | 01:14 PM
jordo's Avatar
at idle it reads 20inHG..
as soon as i touch gas it reads 5psi quick...
Im going to test a mechical gauge tomorrow to see if the car really is boosting 30psi...
i hope it isnt..
Old Feb 22, 2007 | 08:58 PM
jordo's Avatar
Problem solved, I was sent the wrong sensor..
i was sent a sensor for a peak and hold gauge rather then the electronic one.
Old Feb 23, 2007 | 07:02 AM
Mr. Evo IX's Avatar
If you want to know if your overboosting look at your load calc values in EvoScan. The ECU doesnt care about boost, it cares about load. You dont want to be over 260 peak load and want to be in the 200-240 load columns after peak boost.
Old Feb 23, 2007 | 05:08 PM
C6C6CH3vo's Avatar
Wait a second, do you mean your mechanical guage is 30psi or do you have zeitoplug in and your evoscan psi is off?
Old Feb 25, 2007 | 08:08 AM
Mr. Evo IX's Avatar
I think he was saying he was sent the wrong map sensor?
brspeed
Jun 17, 2014 01:52 PM
Ian0611
13
Apr 3, 2013 01:21 PM
808_EVO
10
Dec 2, 2011 12:21 AM
Yamahar1
Nov 18, 2010 06:07 AM
mrfred
Sep 8, 2006 06:42 AM
