boost gauge vs. ECU readings
Anyone compare boost readings off of the ECU (EvoScan w/ Mod23) vs a traditional boost gauge? The reason is that I recently installed a Greddy Infometer touch with an external boost sensor adapter and have been noticing peak boost of 28.9lbs as compared to my 24.9lbs that was logged while getting tuned. Unfortunately, I do not have the Evoscan software to do back-to-back runs but was was wondering if anyone has any feedback.
Thank in advance!!
Thank in advance!!
Hmm right after posting this, I just had an idea. Since the infometer can display multiple readouts at the same time, I was thinking I should use the intake manifold pressure readout and display that at the same time as the external boost readout. Although the ECU provided readout would be peaking at 22.3lbs (Infometer can read the boost off of the CAN output but the Infometer will only show up to 22.3lbs via the ECU), this should be a fare comparison up until that point. I'll post again later tonight with the results.
37 - 14.7 = 22.3 psi
I think OBD2 programs are capped at 22.3 psi or so but the Mode23 in Evoscan 2.6 b16+ should read much higher. My gauge has always read about 1-2 psi higher than actual so when I see 29 psi while my ECU logged readout is 27 psi I don't panic but I can understand your concern. The first issue I've noticed with my autometer gauge is that it sits at 1-2 psi when the car is off depending on high or low barometric pressure. Yours seems to be much bigger of a difference but something to think about.
My thought process goes like this:
Say we are at the track. It would be like me giving someone a tire gauge that read 5psi higher than it really was and telling them that when that tire gauge read 28psi; the laptimes would be the most consistent/fastest. If this was true, then regardless of the actual pressure, as long as the gauge always read the same thing and everything else was "safe", it wouldn't matter... Same would apply to the boost reading. If the boost always read 29psi but was really, 26psi and safe, in the end it doesn't matter.
All that said; anyone else notice differences with their gauges?
Informeter showing 22.3 psi boost limit
If your logging with Evoscan look at your table for PSI. Comes with 14.7 in the formula. Me being at around 5000ft im at 12.3. Best way make it read 0 turn key on (not the engine) and see where your Psi level is at. if its not zeroed out play with formula make it read zero. Then should be dead nuts.
Svendiesel
Mar 7, 2014 12:42 PM
