Need help.. Review my logs plz.
Old Mar 20, 2007 | 06:37 AM
C6C6CH3vo's Avatar
Personally, I can't really decipher much from a log through the gears except that you shift almost as slow as me. The one second of log in 3rd gear shows your making some power but you probable feel that.
The 2.3 consumes more air as seen with 1600hz by 5000rpm, stock turbo?
Old Mar 20, 2007 | 11:38 PM
krillin's Avatar
Originally Posted by Mellon
lol at the misinformation in this thread...
not having knock in 1st and 2nd is common, they are short gears with little time in big boost and do not create as much heat... as you get into 3rd and 4th gear the engine is getting very hot and will often knock. This is why you tune in 3rd and 4th...also you'll get much more data per rpm range in a longer gear.
the timing was lowered due to knock
for good measure I often make 3 or 4 pulls in 4th gear back to back and then tune out the knock. This ultimately gives me a margin of safety.
isn't this what i pretty much said? :P (as far as doing at least three full 3rd gear pulls and pulling timing out to see if knock goes away?)
pfft, no one ever listens to me.
Old Mar 21, 2007 | 02:44 AM
ONRAILS's Avatar
its stock 03 turbo stock boost man.
I'm having a real big problem with my Street Disc clutch and Redline MT90.
It makes for hell to shift this car. My clutch is adjusted all the way out also.
Old Mar 21, 2007 | 04:15 AM
Mellon Racing's Avatar
yes I wasn't referring to you, I was confirming what you already said
Old Mar 21, 2007 | 07:14 PM
C6C6CH3vo's Avatar
Thats the quickest way to toast a new clutch... you wont feel it slip either but keep it like that and you'll be buying a new one again soon
Old Mar 21, 2007 | 09:20 PM
ONRAILS's Avatar
man it will not shift at all in high rpms at all if its anywhere else
riceclown
Oct 4, 2010 04:43 PM
EVOXSILVER
14
Jul 10, 2009 05:46 PM
jmoudry
Apr 18, 2007 08:00 PM
Kings Fan
Dec 30, 2006 04:22 AM
razorlab
Dec 2, 2006 07:46 AM
