Please comment on my graph!
Old Mar 21, 2007 | 08:36 AM
joedr's Avatar
EvoM Moderator
bump
Old Mar 21, 2007 | 11:29 AM
cij911's Avatar
Are you logging boost? Can you tell me when you hit peak boost (24.5)? I am hitting peak boost at about 3600 rpm when I pull from 2K in 3rd gear....Not sure if I have a lazy WG or DV....Thanks
Old Mar 21, 2007 | 12:03 PM
joedr's Avatar
EvoM Moderator
I am not logging boost but I recorded the run on my DEFIs. Obviously, I used 24.5 as an approximate by reading the gauge from Bar to PSI.
I think that my pull was on 3rd gear. I will be logging boost as soon as mrfred send out the JDM map sensor. Will post results!
IMO... I think that peak boost would be around there with your mods. My friend replaced the WG (fp 18 PSI) and it is holding boost considerably better but will have to log his car to see if he is spooling faster with the new WG.
joedr
GSC Motorsports - Charleston, SC
23
Aug 14, 2011 09:54 AM
joedr
15
Nov 4, 2008 02:43 PM
joedr
19
Oct 15, 2008 07:50 PM
joedr
Aug 22, 2008 01:11 PM
joedr
15
May 7, 2008 10:08 AM
