tuning experiment
Old Mar 23, 2007 | 11:23 AM
thatguy's Avatar
OT: 4 Wheel slide how did you disable your meth kit?
Old Mar 23, 2007 | 11:59 AM
4WS Tuning's Avatar
its more than just disabling it.... if you want to make a different map for the car. you can unplug the fuse to the battery or disconnect the power on wire.
i dont advise doing so without knowing how to make a map. the afr's on a methanol tune will most likely put you in the mid to high 12's afr and with high timing thats a garenteed explosion.
pm me if you need some help making a safe map for 93.... what im messing around with i dont reccomend anyone to try unless they have a little experience or are willing to buy a new motor lol
cheers!
Old Mar 23, 2007 | 12:37 PM
nj1266's Avatar
The easiest way to figure out if your making more power with this set-up vs. the meth set-up is to do two 3rd gear logs and run the logs in DLL. That is what I do when I am comparing the power of two tunes.
Old Mar 23, 2007 | 02:36 PM
JohnBradley's Avatar
4 Wheel slide, very interesting data. Do you have the actually log to post? IF its Evoscan or dll or whatever? I am gonna do some experimenting on my own (I have run 28 on 100) but I am curious to see some of the other values that you didnt post.
Old Mar 23, 2007 | 02:38 PM
4WS Tuning's Avatar
ill email you the log... i cant figure out how to use DLL
PM me your email and ill send you the log
cheers!
Old Mar 23, 2007 | 02:41 PM
you got mail
Old Mar 23, 2007 | 02:47 PM
4WS Tuning's Avatar
you got mail
likewise
Old Mar 26, 2007 | 12:48 AM
Spoolin.'s Avatar
I dont understand why you are doing this if you have methanol...
What is stopping you from turning the meth on and running more timing at high boost. I know it is possible to avoid detonation on 93 with low timing but arent you trying to make your car fast here? Get the afr on meth into the high 10s and crank the timing
On my Mirage I run stock timing map's with zero knock on 28psi and pump gas with a pair of Mcmaster Carr M15nozzles and a DIY meth kit. I have no experience tuning EVOs but I dont see any reason why you couldnt do the same thing with this car.
Also why do you keep comparing your car to this mikes1023 guy?
Old Mar 26, 2007 | 01:06 AM
4WS Tuning's Avatar
i interested in how this guy is running the same times i'm doing on 93 that i do on meth.
im selling the meth kit... this is gonna sound funny from all the experiementing i was doing this weekend. but i dont want to have any problems with the car.
it needs to last me a while, so until i graduate and have a job that pays real money. i'm going to play it safe.
cheers!
Old Mar 26, 2007 | 06:31 AM
Spoolin.'s Avatar
You blew it up didnt you
Old Mar 26, 2007 | 08:01 AM
4WS Tuning's Avatar
not yet =-p
Old May 5, 2007 | 01:35 PM
AJsGenerX's Avatar
Delete
Old May 5, 2007 | 03:21 PM
draconx's Avatar
...why delete?
Old May 5, 2007 | 03:29 PM
AJsGenerX's Avatar
I meant my post...I had multiple threads on my screen and I posted in the wrong one lol.
Old May 5, 2007 | 03:38 PM
4WS Tuning's Avatar
slight update.....
i found out on pump im making the most safe power on pump boosting 25 pounds for drag racing.
at 23 pounds its a little better for a lot of partial runs, aka daily driving
