Ecuflash 1.3
Old Mar 24, 2007 | 07:50 PM
dudical26's Avatar
is there anywhere we can still download 1.28 and 1.29 I deleted my old install files and I would like to be able to run 1.28 or .29
Old Mar 24, 2007 | 08:53 PM
TTP Engineering's Avatar
He probably doesn't want it posted here, but:
http://www.norcalmotorsports.org/use...lash_versions/
Old Mar 24, 2007 | 09:05 PM
mrfred's Avatar
Originally Posted by colby
what does the message log say?
colby
I used the v1.29 uninstaller to remove 1.29, and then I installed 1.30 again. When I plug in the openport cable after doing a 1.30 install, a window comes up to install two drivers (openport and openport serial). I install the drivers and try to use 1.30. In the log below, I tried writing a ROM twice. I also tried rebooting the computer after the driver install, but it didn't help.
[00:06:07.562] Version 1.30.1095
[00:06:07.578] 8 memory models read.
[00:06:07.718] 22 ROM metadata models read.
[00:06:07.718] checksum module "subarudbw" loaded.
[00:06:07.734] flashing tool "wrx02" loaded.
[00:06:07.734] flashing tool "wrx04" loaded.
[00:06:07.734] flashing tool "sti04" loaded.
[00:06:07.734] flashing tool "sti05" loaded.
[00:06:07.734] flashing tool "mitsukernel" loaded.
[00:06:07.734] flashing tool "mitsukernelocp" loaded.
[00:06:07.734] flashing tool "mitsubootloader" loaded.
[00:06:27.656] 524288 byte image read.
[00:06:31.203] unable to connect to vehicle interface.
[00:06:46.109] unable to connect to vehicle interface.
Old Mar 24, 2007 | 09:12 PM
MalibuJack's Avatar
Out of curiosity does it recognize the cable in the lower right corner of ECUFlash?
It is a tactrix cable right? Not an E-bay one or anything like that?
Old Mar 24, 2007 | 09:40 PM
mrfred's Avatar
Yep, ECUFlash definitely recognizes the Tactrix cable being inserted/removed. The text changes on the bottom right of the ECUFlash window. The text reads the same as when I am running 1.29. Got the cable from Mynes.
Old Mar 25, 2007 | 09:47 PM
Crufty Dusty's Avatar
MJ, what I've noticed is that the ability to select the COM port has been disabled. i.e. selecting "Options" from the menu just gives the preferences screen. Thus if the wrong port was recognized there is no way to select it.
Old Mar 26, 2007 | 02:13 AM
ONRAILS's Avatar
Same thing mine was doing. Coby please post a link to 129a on your site again i had to go though hell to get it back..
if anyone needs it. I have the installer just hit me up on AIM sn. Violentfun
Old Mar 26, 2007 | 05:57 AM
MalibuJack's Avatar
The way the software works is it doesn't use "Com" ports any longer. It selects it from the driver, so its unlikely to select the wrong cable unless you have two openport cables plugged in at the same time.
If it works like Mitsulogger, it'll select the first device it sees that is an openport cable, and doesn't require any configuration.
Old Mar 26, 2007 | 07:55 AM
Oracle1's Avatar
After new install run setup drivers for cable 1.3. Or connect cable to ecu and reboot computer, this will pick it up as default and install correct driver
Old Apr 1, 2007 | 05:34 PM
96_LXR's Avatar
I'm having the same issue. Just tried it for the first time today. I believe the screen message says something about "unable to load something Evo"?
The strange thing is that I was able to download what was currently in the car but it took waaay longer than it used to.
I would guess it took about a minute to dl.
I'm gonna uninstall / reinstall and see what happens.
Uninstalled the software, deleted the folder, reinstalled and now it is working again. It did prompt me for drivers, selected the defaulst and now it's working.
Old Apr 5, 2007 | 08:16 PM
kmcconn9's Avatar
weird, I dowloaded 1.30 today and came across this error..
Code:
[20:04:51.500] Version 1.30.1095
[20:04:51.515] 8 memory models read.
[20:04:52.406] 145 ROM metadata models read.
[20:04:52.406] checksum module "subarudbw" loaded.
[20:04:52.406] flashing tool "wrx02" loaded.
[20:04:52.406] flashing tool "wrx04" loaded.
[20:04:52.406] flashing tool "sti04" loaded.
[20:04:52.406] flashing tool "sti05" loaded.
[20:04:52.406] flashing tool "mitsukernel" loaded.
[20:04:52.406] flashing tool "mitsukernelocp" loaded.
[20:04:52.406] flashing tool "mitsubootloader" loaded.
[20:04:52.453] error loading FTChipID.DLL
[20:05:02.375] 262144 byte image read.
[20:05:16.718] 262144 byte image read.
Old Apr 5, 2007 | 08:19 PM
nj1266's Avatar
I had a problem with 1.3 as well. I got an error message. So I reverted back to 1.29a and it worked. I have no idea why 1.30 is not working on my lap top.
Old Apr 6, 2007 | 05:56 AM
kmcconn9's Avatar
well I will find out today if the 1.3 works today as I need to make some changes to my idle. It loads a saved rom fine, so we will see.
Old Apr 7, 2007 | 11:50 PM
tirbolag9's Avatar
I am experiencing the same deal. Reverted back to 1.29 and everything works fine. I've also uninstalled/installed a couple of times already and still does not work.
Old Apr 8, 2007 | 12:01 AM
nj1266's Avatar
I think I am getting the same error message that you are mrfred. Glad I kept the 1.29a on my lap top so I can revert back to it.
