How to disable the boost limit
Old Apr 1, 2007 | 02:28 PM
CBRD's Avatar
hey guys...
im hitting boost cut if we go over 28psi on our stroker car...
max value is set to 319, highest it will go... anyway to disable it completely?
thanks
cb
Old Apr 1, 2007 | 02:49 PM
MalibuJack's Avatar
This is something I am starting to run into, I was able to work around it for the time being with my blowthrough setup, but I think there is a way to disable it completely. You probably should post this on Aktivematrix so we can look at it closer.
Old Apr 1, 2007 | 02:50 PM
CBRD's Avatar
Thanks MJ..
im flowing monster air on this thing... load is at 370!! eeks, i rescaled to 340 (evo 8)
cb
Old Apr 1, 2007 | 03:05 PM
CBRD's Avatar
MJ,
what about raising the boost cut timer to some ridiculously high number?
cb
Old Apr 1, 2007 | 03:18 PM
nj1266's Avatar
Originally Posted by CBRD
MJ,
cb
That is what Jestr does on his tunes. He puts a very high number on the timer to delay the cut for a long time.
Old Apr 1, 2007 | 03:34 PM
CBRD's Avatar
i dont know how high of a value it will take...
anyone?
cb
Old Apr 1, 2007 | 04:36 PM
MalibuJack's Avatar
Thanks MJ..
cb
Yeah mine has hit 320 or more even at lower boost levels, so I feel your pain.
Yes, the Boost cut delay timer is the other aspect, you can set that to some silly high number and the boost cut will never really kick in.
The big problem with that is there is the possibility (we're not sure yet) that if you overrun the boost cut value of 319 by some significant number, there is a safety feature that might override the timer setting. But you'll find that out pretty quickly..
Old Apr 1, 2007 | 04:37 PM
MalibuJack's Avatar
anyone?
cb
Just put 99999999999999999999999 in there, it should round to 32767 as the maximum value.
Old Apr 1, 2007 | 05:19 PM
CBRD's Avatar
mine says
1.63838e+06 lol
Old Apr 1, 2007 | 05:23 PM
MalibuJack's Avatar
DOH.. Just to be safe set it to something like 600000
Old Apr 1, 2007 | 05:34 PM
nj1266's Avatar
anyone?
cb
The Jestr tune that I have (I will NEVER flash it into my ECU) has 1638375 in the timer.
Old Apr 1, 2007 | 05:47 PM
CBRD's Avatar
ill try both!
cb
Old Apr 1, 2007 | 07:28 PM
dudical26's Avatar
my max goes to 1638375 which is the same as 1.63838e+06
Old Apr 1, 2007 | 07:57 PM
MalibuJack's Avatar
I completely brain-farted on this one.. You are correct, with the present scaling it has, it goes to 1.6 million.. My earlier definitions had an int16 scaling which would have looked different.
Old Apr 2, 2007 | 05:23 AM
CBRD's Avatar
no worries,
i will see what it does!
thanks cb
