Need help, only boosting 15psi
Old Apr 13, 2007 | 02:52 PM
Sayno's Avatar
I removed the pill near the BCS, and am now able to spike 19psi, but I only hold 15psi past 6500. Before removing the pill i was at 13psi.
I can spike 21psi by going WOT at 2000rpm in 5th, otherwise I never touch 20. Is it because of my altitude? 5500 feet above sea level.
If I get a boost controller will I be able to hold more than 15psi to redline?
Also my boost offset is 80, and wgduty is maxed out across the board, highest load ive ever seen peak is 220. My load at redline is usually 165-175.
When I recently went to Nebraska, at alt. 1800 feet, I hit 275 load and held almost 200 load at redline, with the EXACT same boost levels.
Old Apr 13, 2007 | 02:55 PM
bluebyu36's Avatar
yes u need a boost controler and a tune then you can run higher boost.buy a manual boost controler for under 100 bucks.altitude will affect it but not that much......
Old Apr 13, 2007 | 02:57 PM
EvoInvidia's Avatar
what oct. fuel are you puttin in?
Old Apr 13, 2007 | 03:22 PM
Sayno's Avatar
91 oct, car has 0 knock across the board under all driving conditions. I have logged it a LOT
Old Apr 13, 2007 | 03:25 PM
AF-Evo8's Avatar
I can spike 21psi by going WOT at 200rpm in 5th, otherwise I never touch 20. Is it because of my altitude? 5500 feet above sea level.
yes, and get a tune also.
Old Apr 13, 2007 | 03:54 PM
bluebyu36's Avatar
the car has zero knock because your barely runing any boost.....octane would not affect the boost.........
Old Apr 14, 2007 | 05:17 AM
Jazzie604's Avatar
have you checked for leaks?
Old Apr 14, 2007 | 10:11 PM
hondafan's Avatar
+1. a boost leak check on any evo works magic. most that haven't done it usually have more than 1 leak. i know i did, it was surprising.
Old Apr 15, 2007 | 07:04 AM
MalibuJack's Avatar
High altitude means less dense air, so slightly lower load is expected, but your boost levels are unusually low. I would put the restrictors back to stock until you understand how the factory boost control works, and can adjust it.
If you need to troubleshoot it, you can put an MBC on in place of the stock boost control lines, this will allow you to set a fixed boost level and verify everything else is okay.
If you get about 13psi with little or no change, then the restrictors are mixed up, or you removed all of the restrictors, or you put the line with the restrictor back wrong, and the pill is on the actuator.
If you are getting boost you can regulate, then you need to spend some time working with the boost control tables.
recompile
Aug 29, 2007 08:45 AM
savaho
Jun 2, 2007 06:22 AM
EvoBroMA
Apr 5, 2007 09:15 AM
Noize
28
Jan 30, 2007 07:41 AM
osunick
May 6, 2005 06:39 AM
