Need help ASAP!!!!!!
Old Apr 14, 2007 | 06:20 PM
9sec9's Avatar
did you make a copy of your .hex files anywhere? Maybe a copy on a flash drive or copied from one directory to another? If so, try to find the very first one that you started with and open it from there and look at the immobilizer code.
Old Apr 14, 2007 | 06:22 PM
9sec9's Avatar
Also, look in your recycle bin for the "lost" files.
Old Apr 14, 2007 | 06:38 PM
jdmevo8313's Avatar
Registered User
I found the stock 8 hex file and the immobilizer code is not in it.
Old Apr 14, 2007 | 07:22 PM
jdmevo8313's Avatar
Registered User
On the first post there is a link to a pic of this guys log file. Mine looks just like that.
http://forums.openecu.org/viewtopic.php?t=1969
Old Apr 14, 2007 | 08:03 PM
jdmevo8313's Avatar
Registered User
So is my ECU done or can I do something so i can finally load my stockmap back on?
Old Apr 14, 2007 | 09:21 PM
fixem2's Avatar
If the reinstall and upload and download of your maps is failing then is your car under warrenty? IF so, call Mitsu and ask for a tow.
Old Apr 14, 2007 | 09:27 PM
jdmevo8313's Avatar
Registered User
I only have a catless tbe, ACTstreet/strip clutch and cone filter right now so idk if they will warranty it. Plus Ive had the car fo ralmost 2 years and have always worked it on it and never had it taken to the dealer.
Old Apr 14, 2007 | 09:42 PM
jdmevo8313's Avatar
Registered User
I just set my user level to developer (it was on beginner when I dowloaded it) and immobilzer popped up finally. It is set at 4701. Is this fine to upload? what should it be set at?
Old Apr 14, 2007 | 09:46 PM
hksevoix's Avatar
maybe its time to take it to the dealer, also plan b, buy a new ecu, mitsu supplies one from their works racing program
Old Apr 14, 2007 | 09:53 PM
fixem2's Avatar
The immobilizer is specific to each vehicle. Check that number against some of your other Back up flash files to verify it is correct. IF it is correct, then try uploading.
One thought is to disconnect the battery and let the car sit for a bit. Maybe this will clear something in the ECU. I know it is a long short, but may work.
Old Apr 14, 2007 | 09:55 PM
jdmevo8313's Avatar
Registered User
Ok thanks guys. I'll let you guys know what happens.
Old Apr 14, 2007 | 10:31 PM
codgi's Avatar
I was about to say this is probably why you didn't see it before .
Anyway assuming this code is the correct one then save it a few places in files that are set to read only. Thats what I've done .
Worse come to worse if you can't find it you will have to take it back to the dealership and get them to put back on a stock rom with the correct immobilizer. This has happened to a few other people on here and this what they ended up doing from what I rememeber.
Old Apr 14, 2007 | 10:42 PM
jdmevo8313's Avatar
Registered User
Yeah I just cameback in. I kept getting the samething
"sending init sequence 1 (0001)
sending init sequence 1 (0003)
sending init sequence 1 (FFFF)
no response to any known code"
Mitsu here I come
Old Apr 15, 2007 | 04:38 AM
tephra's Avatar
have you tried a different laptop? check the cable to make sure its in ok nick!
now before you write any more crap to your ECU, read what is currently there, hopefully it will have your imo code in it...
ps i always EMAIL my ROM to myself (gmail/yahoo whatever) account..
Old Apr 15, 2007 | 06:58 AM
MalibuJack's Avatar
Low battery, or bad connection from the white connector..
**OR** you somehow corrupted the rom in the ECU, in that case you can use the ECU unlocker..
What I recommend is load ECU Unlocker, and boost the battery, put your stock rom back on it..
