Need help ASAP!!!!!!
Old Apr 15, 2007 | 06:59 AM
  #31
MalibuJack's Avatar
BTW If you lost your immobilizer code, there's very little I can do to help you.
However if you don't see it, set the option for User Level in ECUFlash to Developer. Next time you load the rom you'll see the init code and immobilizer.
Old Apr 15, 2007 | 09:17 AM
  #32
9sec9's Avatar
If the initcode isn't recognized, it sounds like you have a program from a tuner. Is this your original program, the one you tried to create, or one from another tuner? If it's from a tuner, you may have to use a hex editor to change the init code.
Old Apr 15, 2007 | 09:20 AM
  #33
jdmevo8313's Avatar
Registered User
Originally Posted by MalibuJack
Low battery, or bad connection from the white connector..
**OR** you somehow corrupted the rom in the ECU, in that case you can use the ECU unlocker..
What I recommend is load ECU Unlocker, and boost the battery, put your stock rom back on it..
I just got Ecu unlocker and and it says I gotta open Ecu flash 1.28.
Will it still work with v1.30 or do I have to download 1.28?
Old Apr 15, 2007 | 02:51 PM
  #34
jdmevo8313's Avatar
Registered User
YES I got the Evo back up and running!!!
I want to thank everyone for helping me out
And I want to thank Malibu jack for making theecu unlocker.
Thanks again
-Mario
Old Apr 15, 2007 | 03:27 PM
  #35
burgers22's Avatar
I don't want to give anyone a hard time, but again, DON'T flash the entire ROM from one car to another. If you insist on using every map copy and paste the ones that matter, ignition , fuel, turbo etc. But DO NOT flash the whole ROM.
Anyway, glad your back up and running.
MB
Old Apr 15, 2007 | 03:59 PM
  #36
bone's Avatar
ecu unlocker!!
i had the same problem, my first flash went well, the second wouldnt work. jestr sent me the ecu unlocker and bam i got the new map to work. my car still ran, so i'm glad you got yours fixed, i was just worried about doing any more flashes. all good
bone
Old Apr 15, 2007 | 05:18 PM
  #37
jdmevo8313's Avatar
Registered User
MB
Well all that was changed was the ignition and fuel and it was very conservative because I did not install my AEM UEGO yet, so we didnt do much to it at all.
This wasnt the first time ive flashed my car either. A few months ago I raised the factory stationary rev limiter (2step) to 6k rpm. The only thing this time around was it was very late at night and we decided to load in the map but I forgot to put a battery charger before we loaded the map. It was my mistake and I definatly wont let this happen again lol.
mrfred
Dec 15, 2022 11:13 AM
Burnhad91
Nov 10, 2015 02:43 PM
silver_evo
Jun 25, 2010 11:31 AM
silex
Mar 15, 2010 04:47 PM
Dyrexion
Jan 13, 2009 10:50 PM
