My map.... Is it bad?
Old Apr 17, 2007 | 04:36 PM
ThEHiTMaN's Avatar
Can anyone take a look at my map? PM me your email and I can send it over.
Thanks
Old Apr 17, 2007 | 04:42 PM
VenomEVO8's Avatar
Thanks
PM EVORYDER... he helped with mine.. i had some knock
Old Apr 17, 2007 | 04:47 PM
ThEHiTMaN's Avatar
I am new to all of this..... So this is greek to me.
Old Apr 17, 2007 | 10:12 PM
mchuang's Avatar
If it is new to you, I would read up on some stuff first before jumping in to something like tuning.
Old Apr 17, 2007 | 10:19 PM
ThEHiTMaN's Avatar
Yah... I figured that so that is why I am having people look at my map to tell me what is wrong with it as I did not tune it. It is the learning process I am after also.
Old Apr 17, 2007 | 10:32 PM
codgi's Avatar
Its a vendor map i am guessing and this is why you don't want to post it. Take some logs of the car at WOT that will help the people on here help you more.
Old Apr 17, 2007 | 10:59 PM
ThEHiTMaN's Avatar
Not an EvoM vendor..... So does that count as a vendor map? I'm trying to learn exactly what is going on with it.
Old Apr 17, 2007 | 11:05 PM
ThEHiTMaN's Avatar
Ok here is a 3rd gear pull.
File Type: zip
Old Apr 17, 2007 | 11:12 PM
mchuang's Avatar
How much are you boosting? The reason I asked is because I looked at your log and your are wot@3700 but only hitting around 100 load. You can also add some timing up top. You may want to try and get a log of wot@ like 2800 rpm.
Old Apr 17, 2007 | 11:24 PM
ThEHiTMaN's Avatar
It is around 21-23psi. Would that be caused by a big turbo poor tune and alot of lag? LOL The load doesn't go up until about 5grand.
Old Apr 17, 2007 | 11:42 PM
mchuang's Avatar
nm then I thought you were on stock t. But it does not look like your in any trouble.
Old Apr 17, 2007 | 11:49 PM
codgi's Avatar
Yeah max knock count seems to be 2, which is usually considered good .
Old Apr 17, 2007 | 11:58 PM
ThEHiTMaN's Avatar
My timing seems low..... up top. Also you know what is weird.... my knock happens less at WOT.
Old Apr 18, 2007 | 12:04 AM
mchuang's Avatar
It would be nice to see a log of wideband, but i see you must not have one.
Old Apr 18, 2007 | 12:05 AM
JohnBradley's Avatar
First thing I noticed is that your fuel trims are way off which leads me to believe 2 things:
#1 Injectors are obviously not properly scaled
#2 as a result of #1 Load Calc is completely useless as a reference
Log Hz for the time being, give us some feedback about what your WB is doing (weird swings, deadspots, erratic behaviour, etc.)
I would strongly suggest taking it to Scott at TTP since he is somewhat in your general vicinity apparently. For the amount that your car appears to be off you definitely need on site professional help.
