My ignition maps
Old Apr 22, 2007 | 01:43 PM
andber's Avatar
My ignition maps
Hi,
What do you think of my ignition maps?
I attach high octane ign map 1 and 2.
The car is a euro spec EVO IX running what you in US are referring to as 93 octane (it's called 98 octane here)
Mods are 3 inch full exhaust, walbro 255, mbc and panel filter.
Attached Thumbnails My ignition maps-ignmap1.jpg   My ignition maps-ignmap2.jpg
Old Apr 23, 2007 | 09:12 AM
andber's Avatar
Any comments? I plan to run 23 psi boost over the whole rpm range.
Old Apr 23, 2007 | 10:11 AM
Ph3n1x's Avatar
If you run 22 wiht that same map, youll be faster.
andber's Avatar
Why?
Old Apr 24, 2007 | 04:12 AM
C6C6CH3vo's Avatar
different load I assume. Why not use blocked method (that seems to be shunned upon northern california folfs)
he, he
Old Apr 24, 2007 | 09:49 PM
burgers22's Avatar
That looks like a nice map. Can't say exactly how it will perform for power/ knock etc, but it's a great starting point. On a IX you might be able to run more timing in the mid range.23 psi at the top might be a bit optimistic from a knock/ boost point of view. How are you planning on controlling boost?
MB
Old Apr 24, 2007 | 10:13 PM
JohnBradley's Avatar
Looks a little tame for 93 and 23psi actually. It will definitely be knock free but I have personally run more timing with more boost and no knock.
Old Apr 25, 2007 | 01:40 AM
andber's Avatar
MB
seems like 23 psi at the top is not possible du to boost taper anyway..
I am running 24-25 psi in midrange now, tapering to about 19 psi at redline. I am using an MBC to control boost (Dawes device).
Old Apr 25, 2007 | 01:41 AM
andber's Avatar
Thanks, is it tame all over or in some specific rpm range?
Old Apr 25, 2007 | 02:29 AM
supersnow's Avatar
the midrange is weak, specially for 93 oct
Old Apr 25, 2007 | 08:14 AM
Jeff_Jeske's Avatar
Honestly that map looks almost as tame as my stock 03 map.
Old Apr 25, 2007 | 10:06 AM
andber's Avatar
Ignition is advanced about 4 degrees all over compared to stock map.
Old Apr 25, 2007 | 10:49 AM
Jeff_Jeske's Avatar
There is some advance in the midrange but the top end timing is less in several spots.
Old Apr 25, 2007 | 11:30 AM
andber's Avatar
It's not less than my stock map.
Old Apr 25, 2007 | 05:40 PM
C6C6CH3vo's Avatar
http://innovatemotorsports.com/resources/rich.php
