Interesting find
Old May 6, 2007 | 11:28 PM
JohnBradley's Avatar
Interesting find
As I was changing some information in the data.xml of EvoScan the other day I happened to notice a test for an actuator test to disable 6 injectors. This made sense to me since I knew derivatives of the ECU were used in the 3G V6 Eclipse. So I added the addresses and took a look. While I cant see a direct application for this (other than maybe controlling add'l injectors down the road) right now, maybe someone else has some input?
Injector #1- FC - hex (in hex16) 0000.......I assume this is a V6 and means "off"
Injector #2- FB - 8C00
Injector #3- FA - B48C
Injector #4- F9 - 00B4
Injector #5- F8 - 0000.....again I assume this means its "off"
Injector #6- F7 - 8C00.....repeats for some reason?
I posted this on Aktive as well, but for those that dont venture over there so often I thought I'd share it here as well.
Old May 7, 2007 | 12:28 AM
jcsbanks's Avatar
The request IDs greater than BF represent commands not addresses. So the protocol does include 6 injectors for compatibility with 6 cylinder models.
However, these commands like FC do not reference the address in the ECU memory space &H000000FC. This range of addresses are for the exceptions that are called in response to trap instructions in the ECU code. The address you've shown is &H0000B48C which occupies the 4 bytes from F8 to FB.
Old May 7, 2007 | 02:10 PM
Ahhh, I didnt think it would be so easy. Oh well.
tephra
Oct 18, 2025 06:25 AM
razorlab
5165
Aug 11, 2024 07:56 PM
tephra
57
Dec 23, 2023 09:14 AM
rrstlevo
Mar 25, 2016 12:06 PM
jcsbanks
Apr 23, 2009 07:25 AM
