boost....
boost....
is there a way to control your boost using ecuflash?
i was messing with it today, and it looked like i found where you would change it, but it wasnt in like psi or bar....it was like 254 and 256. am i looking in the wrong area, or what kind of units does it read it in?
The "Boost Desired Engine Load" and "... Offset" tables directly control boost. But, as mentioned above, the stock restrictor pills don't allow for much change in stock pressure.
The values you see there are references to load values, not pressure. The value in the boost desired table added to the load offset table determine the desired load values. Load is directly related to boost, but there isn't really a direct conversion from one to the other. But, basically, the higher the load value, the higher the boost.
You should search. But I understand we are all lazy and don't always know what to search for... so here you go.
How-To set up your car for EcuFlash boost control:
https://www.evolutionm.net/forums/sh...d.php?t=227006
TouringBubble & I's blog on ECU tuning and Boost Control:
https://www.evolutionm.net/forums/sh...d.php?t=266208
(I strongly recommend you NOT try to tune based on the information in our blog. It was highly experimental and more of a learning process. Use it as a reference only, not as a guide.)
For more specific information, there are several expert tuners on this forum that you can PM for help. I'M NOT one of them, but you can PM me quick questions and If I can't answer I'll shoot you to one of them.
Kami Speed
EvoX 'For Sale' Electronics / Lighting / Audio
Feb 20, 2010 03:55 PM
