ROM ID Flashing
Old May 17, 2007 | 10:10 PM
burgers22's Avatar
Hi
I have an Evo 7 ROM xml that alows you to read nearly all the major maps. What is the ROM ID you need to read?
MB
Old May 18, 2007 | 07:42 AM
rice_rocket88's Avatar
Not sure how to get the Rom ID.. there is no ID listed, but it does say Memory ID SH7052 and internal ID: 99860002
Old May 18, 2007 | 07:44 AM
Dennis F's Avatar
Jestr should have the original image from Mike you know.
Old May 18, 2007 | 07:46 AM
Didn't want to put the names out.. but John is having troubles reading the rom now. He said he'll try to rebuild a new one from scratch for me when he has time, but it's been 3 weeks so I thought I'd take a whack at the current maps..
Always get the same error when I try to get into the maps.. can't get into it, it's all greyed out. I can flash and read only
Old May 18, 2007 | 01:01 PM
C6C6CH3vo's Avatar
Bottom line for us 2004 minority population is that we'll have to wait until sombody disses a 96420007 ROM ID.
We've had the worst luck so far - first, 96420008 for some reason was messed up so colby I guess created 0007. Now, no one is interested or has a need to crack the DNA on our ID.
Perhaps 10 of us ea can paypal someone to do it money talks
One more thing - the # on my ECU is:
4602
0008
Would that be 96420008? (just checking for some strange reason)
Old May 19, 2007 | 07:14 AM
C6C6CH3vo's Avatar
I got some #'s here from OpenECU, I have no idear what I'm doing but I guess it's the same as "for dummies" just with these #'s
Old May 21, 2007 | 10:36 AM
jcsbanks's Avatar
39FA2 to 0x8984
39FA6 to 0x8985
Old May 21, 2007 | 11:50 AM
C6C6CH3vo's Avatar
Rock and Roll
Old May 23, 2007 | 05:57 AM
C6C6CH3vo's Avatar
OK, I did the following (below) with the info Mr. Banks supplied for the 96420007 ROM (thanks!) flashed the ECU, used evoscan and logged 2 byte successfully.
Now here's the disclaimer, I did all this without knowlegde of what exactly I was doing which is why I'm posting this - think of it as being posted to get graded and corrected, not as a tutorial (2 byte for retards). But the most important thing is IT WORKS!
Here are some questions:
  1. When I flashed the ROM it processed a hell of a lot of info for just two cell changes (took about 15 seconds), I saved the text of the flash and there was about 3 times the amount of info as usual. Is this normal?
  2. For 2 byte maf I basically do the same thing, right? I want to make sure I did this right before I go and flash 2 byte MAFhz
  3. Getting this to run on LW3 is my next objective now that I got the hard part done, which is the overall picture
An additional comment here, I wouldn't have been able to accomplish _ _ _ _ without the help of jcsbanks who took the time to point me in the right direction (and finding the addresses), so thanks man - I'll vote for you! Also, thanks to Freon for your time as well, even though you may never frequent EvoM
Graded and passed the course!
Old May 23, 2007 | 06:16 AM
jcsbanks's Avatar
1. Normal, it has to flash a large block in high up memory to change the MUT table.
2. Yes
No problem, happy to help.
Old May 23, 2007 | 06:51 AM
burgers22's Avatar
1.When I flashed the ROM it processed a hell of a lot of info for just two cell changes (took about 15 seconds), I saved the text of the flash and there was about 3 times the amount of info as usual. Is this normal?
Yes, jcsbanks can now get all the details of you bank accounts and pass them onto the IRS, big brother watches your Evo...............................
Old May 23, 2007 | 07:30 AM
jcsbanks's Avatar
It is difficult enough finding the details of my own bank accounts
Old May 23, 2007 | 08:17 AM
C6C6CH3vo's Avatar
Mine is easy - -XX
Old May 24, 2007 | 03:21 AM
JoeBee's Avatar
99860002
Thats like my ECU ID
XML appended.
2 Byte load can be found at the forum search for "99860002"
Without warranty !
File Type: zip
Old May 24, 2007 | 10:45 AM
FuelsResearch's Avatar
Apologize if this is a stupid question, just need an affirmative clarification. Will the changes that C6C6CH3vo made to his 0007 rom also work on an 0008? Are 0007 and 0008 interchangeable?
