ROM ID Flashing
Old May 25, 2007 | 07:16 AM
  #31
C6C6CH3vo's Avatar
Originally Posted by FuelsResearch
Apologize if this is a stupid question, just need an affirmative clarification. Will the changes that C6C6CH3vo made to his 0007 rom also work on an 0008? Are 0007 and 0008 interchangeable?
I think if your ID is 96420008 (04) and your running EcuFlash 1.3 then your ID will actually come up as 96420007. At least mine did, with all previous editions of EcuFlash my ROM ID was recognized as 0008
Old May 25, 2007 | 07:45 AM
  #32
FuelsResearch's Avatar
I have 1.3, but rom id is recognized as 0008. Tried to add 2 byte load to 0008 rom. Didn't work, pretty sure I did it right using info from your findings and the other thread (rom for dummies).
Old May 28, 2007 | 04:43 PM
  #33
C6C6CH3vo's Avatar
0008 is the same xml except for idle stepper lookup, is your look up tabel tweeked as 0008 on ecuflash? mine is
Old May 29, 2007 | 02:59 PM
  #34
not sure what you mean by tweeked, please explain. Thanks.
Old May 29, 2007 | 09:13 PM
  #35
C6C6CH3vo's Avatar
The RPM collumns are like 1239000, 390, and so on
Old May 30, 2007 | 04:21 AM
  #36
I figured that is what you meant, yes mine are tweaked.
Old May 30, 2007 | 11:42 AM
  #37
C6C6CH3vo's Avatar
Iff your using ecuflash 1.30 then I thought your ROM would be recognized as 96420007. When I installed 1.30 the ROM displayed as 0007 and the stepper tables were fixed.
The lable on my ecu is 0008
Did by chance you ever run DynoFlash on your ECU?
Old May 30, 2007 | 12:05 PM
  #38
Recognized as 96420008. No dynoflash, but I do have a local tuners reflash.
Old Jun 2, 2007 | 03:54 AM
  #39
C6C6CH3vo's Avatar
It was once thought the ooo8 problems was from the dynoflash but this proves thats not the case, mostly.
Did you get email with working attachments?
Old Jun 2, 2007 | 08:48 AM
  #40
Yes I got the email with the xml and hex file. Really appreciate your help. I edited my xml using your stuff, no errors, but no new tables either.
Old Sep 6, 2007 | 11:01 AM
  #41
eitan's Avatar
OK, I did the following (below) with the info Mr. Banks supplied for the 96420007 ROM (thanks!) flashed the ECU, used evoscan and logged 2 byte successfully. *snip*
I tried this on my 96420007 '04 VIII ROM and EvoScan shows MUT 2-byte load as 0.
Anyone else have this fail to work for them?
Old Oct 18, 2007 | 06:19 PM
  #42
mfr122887's Avatar
I too have the 96420008 rom in my '04. Would it be a problem to just copy over my tables into a stock 94170008 rom and flash that to the car. Since this rom always gets the first of all the mods it would easier. I did some research and it seems as though it should work. Is there anything wrong with this? If it didn't work I could just flash back, right? Thanks
Old Oct 20, 2007 | 01:14 PM
  #43
mfr122887's Avatar
Tried it today and car wouldn't start, so I flashed it back.
mrfred
82
Jan 3, 2020 04:18 PM
Wanchai Panpron
Lancer Engine Management / Tuning Forums
Jul 17, 2017 06:59 AM
Pd1
Oct 11, 2009 05:17 PM
fireroasted
Mar 14, 2009 12:16 AM
Slo_crx1
Nov 19, 2007 02:48 PM
