IX top end boost with O2, WGA tightened
Old May 31, 2007 | 03:31 PM
  #46
Oracle1's Avatar
So....
You run 1.75 bar to 6k rpm (v-power?)
Did you sort the boost creep?
Old May 31, 2007 | 04:03 PM
  #47
Ralph's Avatar
Damn.. you are at 250 load at 7000 rpm????
Crazy..
Old May 31, 2007 | 04:25 PM
  #48
mhgsx's Avatar
There have been quite a few pictures of the junction area where the turbine and wastegate gases meet back up. The wastegate openings are not uniform. Some are large and others have a tiny opening.
Others have experienced boost creep on those with the tiny opening and have rectified their creep by porting out a larger hole.
Old Jun 1, 2007 | 05:27 AM
  #49
jcsbanks's Avatar
Ralph, no 234 load at 7000 at 250kPa MAP, but you can get nearly the same load at only 240kPa MAP so I run that.
Boost creep is now as before the turbo elbow - ie 230kPa at 6000 RPM approx.
Present V-power is 270kPa to 6000 (with peak up to 275-280kPa), dropping thereafter.
It isn't efficient on airflow or timing chasing boost at 7000 RPM.
On warm days with more than 270kPa midrange it needs too much timing removed on V-power, but behaves up to that level.
fabiano
Mar 13, 2016 01:01 PM
axxevo8
Nov 22, 2015 08:20 AM
vxevolutionxv
19
Dec 5, 2006 10:18 AM
Claudius
May 10, 2006 06:41 PM
twkwan
12
Jul 4, 2003 05:44 AM
