O2 Sensor Question
Old May 29, 2007 | 06:17 PM
tephra's Avatar
Question O2 Sensor Question
Hi Guys,
I put in an after market front pipe and now have the dreaded CEL.
I am looking at fixing this in the ECU but before I can I need to understand the rear O2 sensor.
Q) Why do we get 0-5volt readings, isn't it a narrowband sensor?
Cheers
Dave
Old May 29, 2007 | 07:39 PM
RedV's Avatar
Originally Posted by tephra
Hi Guys,
Cheers
Dave
Well, I'm afraid I can't answer your question about the voltages. But I can tell you what I know;
- I have been able to successfully avoid a CEL from the 2nd O2 sensor by using the "spark plug anti-fouler method" described here on the forum. I also have a complete turbo back exhaust with no catalyst. I ended up having success with a single, longer spark plug anti-fouler and then drilling it out almost all the way to the end so the O2 sensor will fit inside it. No SES after more than 2 months now. If you search the forum for "spark plug antifouler" I'm sure you'll find a how-to.
- I have read about a method of "disabling" the second O2 sensor so that it can be completely disconnected. This involved changing some values in the ECU (using ECUFlash and a Tactrix cable for example), and then also using a resistor to simulate the load of the O2 senor heater. AFAIK, no one has figured out how to completely disable the second O2 in the ECU yet, but that might be coming some day.
Hope that helps!
Old May 29, 2007 | 07:43 PM
tephra's Avatar
Thanks RedV,
I am aware of both of those methods, however I guess for my own interest I would like to find out exactly what is going on and fix it proper
Old May 30, 2007 | 04:52 AM
hellcat's Avatar
Deleted.
Old May 30, 2007 | 04:53 AM
hellcat's Avatar
We tried the above method as well on my friends car, but with one antifouler. It worked for 2 weeks without cel until this yesterday. He will put the second one on today.
Old May 30, 2007 | 09:06 PM
tephra's Avatar
anyone?
whats up with the 5V output on the rear sensor? is it narrowband?
Old May 30, 2007 | 09:24 PM
KcEvil8's Avatar
the rear o2 sensor is a narrow band. it goes from 0 - 1 volt. the factory use it to monitor the efficiency of the converter. if the reading from the rear o2 sensor is very close to the o2 sensor in the front for more the a few seconds then it will turn on the check engine light. where did you see it go to 5volts?
Old May 30, 2007 | 09:40 PM
tephra's Avatar
evoscan:
Code:
LogID	TPS	RPM	Timing	O2Sensor	O2Sensor2	Speed	IPW	IDC	KnockSum	LoadMUT2Byte	RPMMUT2Byte
1	13.33	1437.5	7	0.9165		1.248		0	2.304	2.76	0		37.50	1417.96875
2	13.33	1406.25	7	0.9165		1.248		0	2.304	2.70	0		38.13	1417.96875
3	13.33	1406.25	8	0.9165		1.2285		0	2.304	2.70	0		38.13	1425.78125
4	13.33	1406.25	7	0.9165		1.248		0	2.304	2.70	0		37.50	1425.78125
5	13.33	1437.5	7	0.9165		1.248		0	2.048	2.45	0		38.13	1406.25
6	13.33	1406.25	5	0.897		1.365		0	2.304	2.70	0		43.13	1390.625
7	13.33	1375	6	0.6045		1.443		0	2.56	2.93	0		44.06	1386.71875
8	13.33	1406.25	3	0.117		1.4235		0	2.56	3.00	0		43.13	1414.0625
if you like I can post a graph that shows it going up to 5V when on boost...
Old Jun 1, 2007 | 05:01 AM
tephra's Avatar
well another forum told me that there is a muddle up with the MUT requests, apparently 1F is the wrong one, should be 3C...
No idea what im logging then...
Old Jun 4, 2007 | 03:47 PM
JohnBradley's Avatar
I think it corresponds to TPS rather well looking at few logs today.
EVOREZ1992
Feb 7, 2015 04:16 AM
Jav53_evoix
Aug 5, 2014 03:30 PM
evilevo22
Oct 3, 2007 02:36 PM
evilevo22
Feb 27, 2007 01:39 PM
o2yellowlancer
Lancer Engine Tech
Mar 1, 2006 09:42 PM
