Wastegate Solenoid Activation RPM
Old May 4, 2008 | 04:32 PM
  #31
RazorLab's Avatar
Originally Posted by mrfred
The "Deactivate On" value looks wrong. That setting is the upper rpm where the BCS turns off (and thus boost will drop). It should be something like 7500 rpm. The "Deactivate Off" should also be set to something like 7500 rpm.
That is how it is stock on the 03-04 roms, which makes me believe the def for that map in those roms is incorrect.
Old May 4, 2008 | 05:17 PM
  #32
mrfred's Avatar
Must be. Otherwise the cars would be slugs after 3250 rpm.
Old May 4, 2008 | 05:18 PM
  #33
racer135's Avatar
In my logs if I go over 7500 RPMs the WGDC jumps to 100% but then I hit rev limit fuel cut so the boost don't have time to go up (if it could at that RPM which I doubt). With that behavior I cannot raise the rev limiter.
My ROM ID is 96420008. How can I get the correct value for that table? Do I need any special tool for that?
Old May 5, 2008 | 12:33 PM
  #34
bärtil's Avatar
Correct table address for atleast EDM VIII is 1a68, i havent tested but found it from disassembly. Test and report if it works.
Old May 5, 2008 | 07:13 PM
  #35
racer135's Avatar
Looks like that the correct address for the VIII. I have not tested it yet but the values I get at the table on ECUFlash makes more sense. Same values as the ones for EVO IX. Thanks you!! I will test in my car tomorrow. For reference to others heres what ECUFlash gave as stock values.
Old May 5, 2008 | 07:18 PM
  #36
mrfred's Avatar
Those are indeed the correct locations for the 94170008/14/15 ROMs.
Old Sep 28, 2008 | 02:47 PM
  #37
mchuang's Avatar
Wow this is the reason my solenoid has been clicking from 2000 rpm to 8000 rpm. Everytime I would let the throttle go below 2000rpm the noise clicking would go away. Once I went over 2000 it could come back all the way to redline.
Old Oct 6, 2008 | 08:54 PM
  #38
Jack_of_Trades's Avatar
I just installed my GM 3 port recently and its loud as a **** and I cruise between 70-80mph on the highway on my commute to work which is upwards of 3300rpm and the solenoid clicking is driving me nuts. If I set this table to 3300rpm would it keep the solenoid at 0% until it exceeds that rpm value? Its either that or just keep my base WGDC values at 100% up til 3400rpm, both should do the trick but I wanted to understand this table a bit more.
(Slightly off topic)
Also, I noticed the error correction will hang onto the last known % adjustment until it sees a change, so if I was at +4% correction at the end of a pull...then I cruised....then got on it again it will start the next pull at +4%. Is there any way to have it reset the correction value after it sees the load or tps drop below a certain amount so I can start 'fresh' with every new pull??
Old Oct 6, 2008 | 09:07 PM
  #39
tephra's Avatar
mine is quiet as a mouse.
I DID however use a thing bit of foam between the GM3port and the chassis where I mounted it (same bolt hole as original...)
I have never noticed the correction hanging like you say.. that's weird..
Old Oct 6, 2008 | 09:15 PM
  #40
RazorLab's Avatar
The 03-04's run 100% WGDC until a certain load/tps/rpm, unlike the 05-06 which run 0% until a certain load/tps/rpm, basically until "boost control" turns on and it reads from the base WGDC table.
The hanging correction this is odd, might be a 03-04 thing as well.
Jamie, what update interval do you have set?
Old Oct 6, 2008 | 09:52 PM
  #41
racer135's Avatar
From my experience I believe the 04 also run 100% WGDC until a certaing temp is reached. Thats not a very good idea if you run a GM 3 Port since you can easily overboost when cold. It has happened to me.
I am not sure if there is an easy way to eather lower that temp limit or just make it 0% like the 05-06. That is definitely safer that running 100%.
I was thinking about using an additional GM 3 Port driven by a collant temp switch to put the turbo at WG pressure when cold but never really put much thinking into it. I just drive slow for at least 2~3 min when cold.
Old Oct 6, 2008 | 10:00 PM
  #42
tephra's Avatar
There is a cold running WGDC map...
Old Oct 7, 2008 | 12:37 AM
  #43
RazorLab's Avatar
They run 62.5% until up to temp as default. Remember stock runs 100% WGDC all the time at WOT unless error correction kicks in.
Old Oct 7, 2008 | 04:05 AM
  #44
My car runs 0% WGDC until coolant temp is reached. I have my interval set to 1 BTW. So the correction is supposed to reset back to zero under certain conditions???
Old Oct 7, 2008 | 08:18 AM
  #45
racer135's Avatar
Is there a way to make them run lower WGDC; something like a 40% or even 0% to avoid any overboost before reaching operating temp. I would be very insterested in that. It will help a lot specially when my wife for any reason has to borrow my car. I try to avoid that like the devil to the cross but sometines it happens.
