EvoScan v1.0 - Now with Feature Request tracking.
Old Jul 3, 2007 | 04:22 PM
  #31
Jumperalex's Avatar
This seems too petty for the issue tracker (where I just added another requested feature) but is there a chance at getting the mouse-over pop-up to not go away after a time?
Old Jul 8, 2007 | 07:10 AM
  #32
tkklemann's Avatar
Originally Posted by l2r99gst
EvoScan has the high and low long terms trims switched. 0C is LTFT-low, 0D is LTFT Mid, 0E is LTFT High, and 0F is STFT.
Also, the equation should be (.1961x)-25. This will give you the actual percentage of fuel the ECU is adding or subtracting.
Eric
Eric,
I went in and changed my Fuel trims to the correct designations you have above, as well a changing the equations listed above in the data.xml file. I do not see an equation for the STFT 0F..
Can I make a new line, exactly like this, to create a Short Term?
<DataListItem DataLog="Y" Color="" Display="Short Term Fuel Trim" LogReference="FuelTrim_ShortTerm" RequestID="0F" Eval="(.1961x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="200" ChartMin="0" ChartMax="200" ScalingFactor="1" Notes=""/>
Sorry, I am trying to learn all of this stuff, and am playing with the data.xml file now to arrange the things I want the most at the top and what not..
Old Jul 8, 2007 | 07:27 AM
  #33
l2r99gst's Avatar
Evoscan has the 0F request, but it is called something like O2 feedback. The request is already correct. The formula just needs to be changed and you can change the name to STFT if you want, since that is what is really is.
Eric
Johnny Boy
Feb 16, 2010 12:51 PM
evo4mad
Mar 22, 2009 08:38 PM
Inprogress
Feb 5, 2007 07:12 AM
evo4mad
Oct 12, 2006 11:30 PM
