Injector scaling ? AFR - WOT
Old Jun 17, 2007 | 03:23 PM
Oracle1's Avatar
If I get my fuel trims spot on ( ) and when testing WOT I see my AFR is running richer than before (Eg was 11.5 and now is 11.2), Can I rescale the Injectors to sort this out? (scaled at 665, should I try 680?) Would I also need to re-adjust the latencies to accomodate the injector scaling? Or not?
A bit confused
I need some clarification please
Old Jun 17, 2007 | 06:25 PM
l2r99gst's Avatar
No, don't touch the injector scaling. Your use your fuel maps to then tune your AFR.
The injector scaling and latency values are used to get the trims in check. Once your trims are good, then use your fuel maps for open-loop AFR tuning.
Eric
Old Jun 18, 2007 | 02:42 AM
Oracle1's Avatar
Thank You!
Old Jun 18, 2007 | 04:42 AM
MalibuJack's Avatar
Yeah once your in the ballpark, then you can work with the maps..
The value in the map, and the actual value are never "Spot on" unless you spent TONS of time with all of the latency settings available (there are 2 more settings besides the voltage latency, but not really that useful to adjust)
The closer your trims are for low/mid/high the closer the fuel map values, and actual AFR's will be.. However Intake anomolies, and other things that can affect load slightly will always skew the values a bit. Be happy that the numbers are close enough that you can baseline changes.
Old Jun 19, 2007 | 06:18 AM
Mellon Racing's Avatar
I agree, it sounds like you're close enough to start tweaking the map itself if you're trims are where you want them.
lancerrally45
May 31, 2016 11:09 AM
Raceghost
May 21, 2016 12:37 PM
mac214
Sep 23, 2009 06:21 PM
Smogrunner
E85 / Ethanol
21
Aug 3, 2008 09:05 AM
EgoBstr
Feb 14, 2008 01:50 PM
