Your opinions on my self-tune are appreciated
Old Jun 21, 2007 | 06:36 PM
recompile's Avatar
Yep, Hallman Pro... at least it holds boost better than my Forge... the Forge sucks beyond 20psi
Old Jun 21, 2007 | 07:55 PM
mrfred's Avatar
Can you post one of your latest good logs?
Old Jun 22, 2007 | 03:47 AM
recompile's Avatar
Sure thing. http://out.psysem.com/EvoScanDataLog...1_20.35.10.csv
Old Jun 22, 2007 | 03:52 AM
TeStUdO's Avatar
ShamelessCookie, your timing looks a lot better now. Definitely not as erratic. Did you make all 3 ignition maps the same to remedy the problem?
Old Jun 22, 2007 | 04:37 AM
recompile's Avatar
Yes, I made all 3 High's the same.
Old Jun 22, 2007 | 06:59 AM
mrfred's Avatar
I plotted up your latest data. According to my calculator, TQ has definitely improved in the lower rpm range, but HP is just slightly improved. The Load and IDC both show that something funny is going on with load in the 3500-5500 rpm range. In my experience, boost mirrors the load curve, so I'm thinking that your boost is peaking, and then falling off to around 21 psi at 4500 rpm. If you can get that fixed up (still holding 23 psi at 4000-5000 rpm), you'll definitely be pushing 300+ ft-lbs of TQ at 3500-4000 rpm. Higher rpm is interesting. The AFR and timing are both very optimal. Load isn't very high though. I'm wondering if some MIVEC tweaking or more psi would get you cleanly past 300 WHP.
Attached Thumbnails Your opinions on my self-tune are appreciated-shamelesscookie_evoscandatalog_2007.06.21_20.35.10.jpg   Your opinions on my self-tune are appreciated-shamelesscookie_evoscandatalog_2007.06.21_20.35.10_hptq.jpg
Old Jun 22, 2007 | 07:49 AM
nj1266's Avatar
According to DLL, The torque is @ 305 ft/lb and hp is at 320. I poltted his log and used the temps from his earlier DLL in the first post. Looks like s good tune and dyno plot to me. The car could hold the torque longer by manipulating the boost, but the torque is there.
Attached Thumbnails Your opinions on my self-tune are appreciated-shameless.gif
Old Jun 22, 2007 | 08:13 AM
Mr. Evo IX's Avatar
Dont be concerned about your fuel map being blocked. Here's mine and our car's look extremely similar from your logs. Rock solid 11.1 AFR to redline with 12.5 at spoolup.
Old Jun 22, 2007 | 08:25 AM
mrfred's Avatar
I used the same calculator that I used in my previous post, and when I compare to that, the gains are mainly in TQ.
Old Jun 22, 2007 | 08:56 AM
recompile's Avatar
Thanks everyone for your continued support.
The MIVEC in that log is not what I'm using now, I was experimenting with the 6000-7000 and I've smoothed that out so it doesn't dip so badly.
It's definitely smoother. I may try throwing my stock airbox on, right now I'm using a K&N Cone Filter
Old Jun 22, 2007 | 09:52 AM
nj1266's Avatar
You probably know this, but if you put your stock airbox back, then your load will become lower and you might have to re-tune your fuel map.
Old Jun 22, 2007 | 09:55 AM
recompile's Avatar
Might help smooth my load curve.
Old Jun 22, 2007 | 02:55 PM
recompile's Avatar
I currently have my Hallman Pro hooked up Turbo > Wastegate... after researching other peoples' results with MBC hookups, I'm going to try changing to BOV > Wastegate. It seems to be less taper and less spikey.
recompile
May 4, 2025 01:39 PM
recompile
Nov 24, 2007 04:33 PM
recompile
Nov 3, 2007 03:21 PM
recompile
Jul 8, 2007 05:42 PM
