another log to view evo8
Old Jun 23, 2007 | 11:35 AM
nothere's Avatar
since I enjoy looking at other people's logs here is one from me.
read on a lapping session going down the straight away, I am injecting water about six inches before the throttle body, evo 8, WR turbo, 262 cams, mid way through a twenty minute log.
other readings from a similar location showed a bit of knock so a degree more timing has been removed from around 5k and 7k.
I've found on my car a lot of track time knock comes from mid throttle load so my map is a little different than most.
http://docs.google.com/Doc?id=dcwsmvt8_23drfx9z
File Type: doc
Old Jun 23, 2007 | 02:34 PM
Mellon Racing's Avatar
low 12's AFR... I hope you're running race gas, that would be extremely lean on pump gas.
Old Jun 23, 2007 | 03:18 PM
nothere's Avatar
running 92 gas, but injecting water right before the throttle body.
Old Jun 23, 2007 | 03:31 PM
nothere's Avatar
here is the timing map
http://docs.google.com/Doc?id=dcwsmvt8_246656k9
Old Jun 23, 2007 | 05:48 PM
C6C6CH3vo's Avatar
Nice AFR and timing - I noticed low 12 AFRs are perfect if timing is no more than optimal, esp with water
sp00lin9
Jul 23, 2017 07:36 AM
Ferp
Mar 11, 2017 09:50 AM
spomi
Cobb AccessPORT
Oct 8, 2016 05:30 PM
turbotaloon95
Apr 11, 2016 06:58 AM
