ecu responding to nothing, locked?
my car was being tuned on the dyno last night
anyways, we were playing with the fq360 maps and by accident (and my stupidity) i put the whole fq360 map on my car. now this normally wouldnt be a problem, except the wrong immobilisor code is in the car.
but then i got the 'no response to any known code' so i could not connect to the ecu anymore.
could not read, could not write, could not do anything! so basically, i had the wrong immobilisor code stuck in the car and could not change it, so the car would not start.
in the end, i had to borrow someone else's ecu and put my code on it so i could use the car (and keep tuning).
now i have only borrowed the new ecu, so i would like to try and fix my one.
is it cooked? locked?
can i somehow reset it? wipe it and put my maps back on it?
everytime i try and connect to it it wont initialise
thanks in advance
thanks in advance
When in doubt, always try to use the unlocker.. 90% of the time its the init code, there are rare occasions the flash gets corrupted, but the unlocker triggers the ECU's recovery bootstrap which will allow you to read/write most mitsubishi ECUs that won't work otherwise.
jsr426
78
Mar 30, 2009 12:03 PM
Cirrusly Evolvd
Mar 9, 2007 12:18 AM
