Help, my tune
Old Jun 28, 2007 | 07:01 PM
C6C6CH3vo's Avatar
Was that second gear logs? The speed appears to be 2nd but the time 3rd. Just curious
Old Jun 28, 2007 | 07:03 PM
wrcwannabe's Avatar
Yes those are 1st gear then a 2nd gear. Very short ones. And 4 secs 3000 to 6000 so slow?
Milburn
Old Jun 28, 2007 | 08:15 PM
jordo's Avatar
Originally Posted by razorlab
What open filter?
4" k&n...
I think that is the issue, i think im going way over the load maps..
When i read through the logs, they only state 270ish range though, but tuning in those columns it does not effect anything.
Old Jun 28, 2007 | 08:17 PM
RazorLab's Avatar
Are you reading our posts? Your calc load is inaccurate since you have larger injectors and it is based off the stock injector scaling. I stated that in one of my earlier posts. You are easily over 270 load with a GT3076 at 22psi.
Change the higher load sites (baby steps!) and you will start seeing changes in your logs. I would bet a beer on it.
Maybe try something like this:
Code:
200	220	240	260	280	320
-10	-10	-10	-10	-10	-10
-6	-9	-10	-10	-10	-10
-4	-7	-10	-10	-10	-10
-2	-5	-8	-10	-10	-10
2	-1	-4	-7	-7	-7
2	0	-3	-6	-6	-6
5	2	-1	-4	-4	-4
5	5	4	3	2	2
6	5	4	3	2	2
8	7	5	4	3	3
8	8	7	5	4	4
8	8	7	6	5	4
9	8	8	7	6	5
10	9	8	7	7	6
11	10	9	9	9	7
12	10	10	9	9	8
12	11	10	10	9	8
Old Jun 28, 2007 | 08:24 PM
jordo's Avatar
I am reading your post, what i do not know how to do is get it in "range" or to make it where it actually reads correctly.
I have tryed pulling fuel at 300 and it still does not respond.
Old Jun 28, 2007 | 08:26 PM
RazorLab's Avatar
I added to my post above as far as some timing ideas. YMMV
If you are changing fuel with no response from your wideband (showing 10AFR) with over 10.2 in your fuel maps then I think something is wrong with your wideband.
Old Jun 28, 2007 | 08:42 PM
nothere's Avatar
if an injector is "sized" /scaled to rich it is entirely possible to have your fuel map actually read what afr you intend to run.
I had a map that was by and large 12.x to 12 .x in the load columns, which is what I am tuning for with water injection.
Since I got my scaling corrected, thanks to one of razorlab's posts, the map now looks like it did originally, with all those ridiculous late nines and tens.
Old Jun 28, 2007 | 08:48 PM
RazorLab's Avatar
Yup you are correct, but his 780's look to be scaled correctly from the screenshot he posted, unless I am looking at it wrong.
Old Jun 29, 2007 | 07:30 AM
l2r99gst's Avatar
jordo,
You can modify your ROM to log 2-byte load, if you want to know for sure what load cell you are in.
As far as the rest of the post and comments recently: you say that you have a 4" K&N with your 3076. Is this a new addition, both the filter and the turbo?
Also, you haven't messed with your MAF scaling, have you?
You are simply flowing more air than you think, whether it is because of the combination of your filter and turbo messing with the MAF, or simply because you are flowing more air.
You may have to rescale your tables to go beyond the 300 load column. When you go straight to 10:1, it could be your wideband like Bryan stated, it could be that your MAF reading is screwed up, or it could be that you are overrunning your load tables and the ECU is adding even more fuel than the maps state, or a combination of all of these.
Also, sorry if this was mentioned earlier, but what are your long term and short term fuel trims? It may be as simple as dialing in your injectors properly.
Eric
Old Jun 29, 2007 | 08:13 AM
Ph3n1x's Avatar
Of course the load is wrong....Evoscan calculates it with "513cc" as a constant. That needs to be updated to ur current IDC.
Old Jul 2, 2007 | 03:00 PM
jordo's Avatar
I tried rescaling up to 390, still not responding.
2byte load says it goes to 379 and holds at 379.
short term and long term are both at 100
Old Jul 2, 2007 | 04:10 PM
l2r99gst's Avatar
There are three long term trims, low, mid, high. 0C is low, 0D is mid, 0E is high. There is one short term trim, 0F is STFT. Evoscan has low and high LTFTs switched. If your low and mid LTFT are both 0 (100), then your injectors are scaled fine, but double check that you are logging the correct requests that I have mentioned. Your LTFT low may actually be off. Also, they may reset to 0 after a flash, so look at your STFT to see what the ECU is trying to do at idle and cruise.
Your 2-byte load of 379 is not surprising. Now, at least we have confirmed that you are well past your normal tables. That is way too high even for your turbo at 22 psi, though. Have you messed with your MAF scaling by any chance?
Also, as far as your 2-byte load of 379...do you have a graph of this? I want to see if it just plateaus at that spot. I remember reading that the ECU has a max maf/rev value and if it passes that value there is another table that will replace it. Maf/rev is basically = load. Actually, quoting Bez from one of his disassembly thread, base LOAD=MAF_PULSES_PER_REV*MAF_SIZE*2^17.
So, I am wondering if you are hitting this load 'limit', which may be also causing your fueling issue. I would think that plenty of people have seen past a load of 379, though, with 35rs at 30 psi, etc. Also, please let us know if you have changed anything in any of your MAF tables from stock.
Eric
Old Jul 2, 2007 | 11:08 PM
jordo's Avatar
I fixed the issue..
My intake setup was crappy, so i bought a FP intake arm and used the stock intake box.
also had a boost leak which was overspooling the turbo, resulting in weird MAF settings..
I finally have it ready for tuning now..
Thank you guys, ill post my new map and logs so you guys can look over.
Old Jul 3, 2007 | 05:41 AM
TouringBubble's Avatar
Glad to hear that you got it figured out.
bbarnhill
May 4, 2021 08:32 AM
TouringBubble
Feb 11, 2008 02:01 PM
Thoe99
Nov 26, 2007 06:35 AM
evo4mad
Oct 12, 2006 11:30 PM
stingerbtry
Jul 14, 2006 05:23 AM
