how to let torque hold longer?
Old Jul 10, 2007 | 06:01 PM
AhBao9388's Avatar
Originally Posted by chrisw
anywhere to tune in maylasia? there has to be some good empty roads up there that is resonably accessible to singapore
knock is not gear dependant. aggresive timing changes between cells is.
for example
at 2500 pm starting in the 160 load column you have the cells
12, 6, 3
then at 3000 you have
12,12,7
if you trace a line that represents your load as you move through the power band, any large jumps in timing can cause knock.
I try to keep the large jumps in timing to a minimum. If you can't get rid of the large jump in timing, check you fueling at those load points.
guess would only be able to do that on a weekend then. so meaning to say if i wan to let my torque hold longer, i increase the timing more?
Old Jul 10, 2007 | 07:58 PM
chrisw's Avatar
increase it or hold it around no more than 8 degrees at peak torque. This is what I have been told by several well respected tuners who regularly post in this forum.
I try to hold the most timing I can without knock and while keeping the AFR values in a safe range.
Old Jul 10, 2007 | 08:15 PM
AhBao9388's Avatar
ok guys. i did a 3rd gear pull just now and it seems that the torque is higher than in 2nd. so thru this graph have i max out my stock turbo? is there any chance i can still go further? could i let my torque drop from 6k rpm instead. aggressive timing?
Old Jul 10, 2007 | 08:29 PM
Jorge T's Avatar
Change your Units to imperial, Metric will make it look funky
192 KW=257 HP, 347Nm = 255FtLb
Old Jul 10, 2007 | 08:30 PM
gunzo's Avatar
just change the plot range TO portion at the end of the run to the highest rpm you hit.. or 1 - 200 rpm less..
Old Jul 12, 2007 | 01:42 AM
alanoh's Avatar
Need space to run
AhBao,
Call me lah.... I know where we can do 3rd or even 4th gear run in our little island.
Alan (aka JudgeJules)
Old Jul 12, 2007 | 05:11 AM
AhBao9388's Avatar
Originally Posted by alanoh
AhBao,
cannot la. i dont want to go against the law im a law abidding citizen
AcePitcher11
Dec 22, 2019 04:39 PM
Tobra
Lancer Tranny/Drivetrain Tech
Jun 3, 2017 08:17 PM
Shaun@AWDMotorsports
Nov 2, 2015 09:15 AM
PeteyTurbo
GSC Motorsports - Charleston, SC
14
Sep 8, 2008 09:13 PM
TURBODAWG
73
Feb 9, 2006 08:38 AM
