evoscan > 250 load
evoscan > 250 load
im now going beyound the max load in evoscan, so looking at the graphs its cuffoff after 250 load. Is there a way to increase this to 300 or more to match the ECUFLASH.
those post are for rescaling the ECUFLASH for from a 260 to a 300 load resolution.
What I am asking is evoscan resolution which is 250 load. I want to increase this to 300 to match ecuflash.
If you find that your load value is "topping out" at 250, and this value is derived from a 2-byte mod, double-check your 2-byte mod to ensure you've got the proper edits for your ROM. If you're referring to LoadCalc, I'm not sure what to tell you. I don't know of any reason that your load value would be capped at 250 unless, of course, you're not actually going beyond that.
^^ the graph utility is probably intelligent. It won't show much more that whatever the max value you are graphing. A simple test is to edit the log and put load up above 250. The y-axis will extend (I just looked at my logs and they go past 250 and y-axis now goes to 300).
okevolutionVIII
Jan 1, 2014 10:15 PM
