Any Interest in More Custom Pills?
Old Jul 26, 2007 | 10:10 AM
  #31
HaVoC RR's Avatar
#65 pill please add me too the list
Old Jul 26, 2007 | 10:40 AM
  #32
nj1266's Avatar
CUSTOM BOOST PILLS LIST:
1. nj1266, 3 #65 pills
2. Pd1, 1 #65 pill
3. chmodlf, 1 #63, 1 #65
4. codgi, 1 #63
5. RedV, 1 #65
6. FuelsResearch, 1 #63, 1 #65
7. Turbo81, 1 #63, 1 #65
8. NyC DrifteR, 1 #65
I need two more guys. I just got off the phone with the machine shop and he told me that he has everything ready to commence production of the pills. All he needs from me are the number of pills needed. So far we have 13. We need two more to get the best possible price.
Old Jul 26, 2007 | 12:10 PM
  #33
RedV's Avatar
You can change mine to both a #65 AND #63 instead of just the #65 if that'll help. Plus I'm asking my friend with a white MR if he's interested.
Hey, BTW... how easy is the pill by the turbo to remove? I know that the one by the solenoid can be a PITA.
2. Pd1, 1 #65 pill
4. codgi, 1 #63
5. RedV, 1 #65
Old Jul 26, 2007 | 01:00 PM
  #34
Last4G63's Avatar
I'm the friend with the white MR, I am in, just not sure exatly which direction I want to go.
What is the maximum boost and tapering characteristics of the 65 vs the 63? From the posts thus far it appears that the 65 is good for 22-23PSI max with a taper down to 20PSI? So same max boost as the stock EBCS running 100% WGDC, BUT has better tapering characteristics (only tapers to 20 as opposed to 17 or so stock). And the 63 is good for 28PSI with a taper to 20PSI?
I want the ability to run 25PSI with race fuel and a taper to 20PSI. I would most likely run 22-23PSI on the street and taper to 20PSI or so. Which pill do I want?
Old Jul 26, 2007 | 01:03 PM
  #35
Zeus's Avatar
nj1266,
Sent PM
Old Jul 26, 2007 | 02:30 PM
  #36
Jorge T's Avatar
Add me for a #65
Old Jul 26, 2007 | 02:38 PM
  #37
Tsurugi-san's Avatar
So this is how WORKS did it . . .
Old Jul 26, 2007 | 03:09 PM
  #38
nj1266's Avatar
The smaller the orifice in the pill the higher the boost you can run. The #65 pill will allow you to run higher boost than the #63 pill w/o maxing out the WGDC. Nuked maxed out his WGDC in order to spike to 28 psi. You can do that with the #65 pill and run lower WGDC numbers in your rom.
I was able to hit 21-22 psi and hold it all the way to redline with the #65 pill on 91 octane gas. With higher octane I am sure I can run more.
Should I add you to the list for a #65 pill?
Old Jul 26, 2007 | 03:11 PM
  #39
nj1266's Avatar
Removing the hose assembly is a PITA. The best way to do it is from under the car, but you will have to remove the tray which is another PITA
Old Jul 26, 2007 | 03:14 PM
  #40
nj1266's Avatar
2. Pd1, 1 #65 pill
4. codgi, 1 #63
5. RedV, 1 #65
9. Zeus, 1 #65
10. Jorge, 1 #65
I think we have the 15 pills that we need. I will call the shop on Monday (closed on Friday) and give him the go ahead and the number of 63 and 65 pills we need.
Old Jul 26, 2007 | 03:16 PM
  #41
mplspilot's Avatar
Put me down on one #65 if possible
Old Jul 26, 2007 | 03:23 PM
  #42
nj1266's Avatar
2. Pd1, 1 #65 pill
4. codgi, 1 #63
5. RedV, 1 #65
9. Zeus, 1 #65
10. Jorge, 1 #65
11. mplspilot, 1 #65
The more we have the better deal we can get. Hopefully, over the next 3 days more people will sing up.
Old Jul 26, 2007 | 03:36 PM
  #43
Last4G63's Avatar
Please put me down for both a 65 and a 63 as well. Also, I've added RedV's request for both a 63 as well as a 65.
2. Pd1, 1 #65 pill
4. codgi, 1 #63
5. RedV, 1 #65, 1 #63
9. Zeus, 1 #65
10. Jorge, 1 #65
12. Last4G63, 1 #63, 1 #65
19 pills total thus far... Nice!
Old Jul 26, 2007 | 03:46 PM
  #44
nj1266's Avatar
2. Pd1, 1 #65 pill
4. codgi, 1 #63
9. Zeus, 1 #65
10. Jorge, 1 #65
Thanks for the update
Old Jul 26, 2007 | 11:45 PM
  #45
codgi's Avatar
Actually add a #65 for me too....just in case .
