conservative meth tune?
Old Jul 20, 2007 | 05:41 PM
jroller's Avatar
I was hoping to get a response from some of the guys that have tuned for alky. I have an SMC V2 kit Ive had laying around. Assembled everything hooked it up to 12VDC and ran some water though it. Everything works great I want to know if my ecu can be flashed with a conservative meth tune? Meaning that I could run 91 octane as usual and not damage the engine, or run 50/50 meth and water. I understand timing and fuel trim would not be maximized while on alky. However Im not looking to eek out every little bit of HP rather a cooler denser intake charge with less overall chance of detonation. Id be more than happy with a gain of 15ftlbs increase over current setup. Also when is alky doing the "most" on the initial boost spike or @ higher piston speeds ie 7,000 RPM?
Current Setup
-TBE
-MBC
-UICP
-Drop in Filter
-Tune
-255lph pump
-Stock Clutch!
