Need your help.... please read
Old Jul 20, 2007 | 09:30 PM
LoRo's Avatar
So to make a long story short I moved from Seattle to Las Vegas. I had my car shipped and the company did 12k worth of damange and paid to have it fixed. One of the things replaced was the PCM or ECM. Now I got my data logger cable and am able to read my stock map. I have a few issues.
1. Is it normal for the EvoScan or ECUFlash to cause the ACD / ABS lights to blink while connected? If it is, would this be safe to do a log on? If it is not normal anyone have any steps for me to try. I got the full bundle for limitless's website.
2. I had been tuned / flash for what i would call mid performance (20psi max) I got the car back and the only thing I changed was I upgraded my stock MR blow off valve to a GFB Stealth FX and only venting a little bit of air (maybe 10%).
3. I'm hitting fuel cut / getting the P0234 overboost code. I turned down my manual boost controller because I was hitting the fuel cut right in the 4.5k to 5.5k range and would imedeatly throw a SES light.
If someone can help me fix the above issues that would be really helpful as I don't know anyone here in Vegas but need to resolve this ASAP.
Kind Regards,
Loren
Old Jul 20, 2007 | 09:32 PM
LoRo's Avatar
Oh I turned down my MBC and I'm only maxing 15.5 to 16PSI all the way up to around 6k. forgot to add that.
Old Jul 20, 2007 | 09:40 PM
JohnBradley's Avatar
Assuming that you are going to tune this yourself, go to the boost limit under the turbo heading. What you will see is probably is something like this:
255
255
255
255
250
245
240
235
235
Each corresponds to an RPM point and references a load % in your tuning maps. Up these about 20 across the board and your fuel cut will/should be fixed. The blinking light thing I havent ever seen before but if the car still operates and isnt flashing when unhooked I wouldnt be overly concerned.
The best course of action would to be retuned by a local. Doug's Dyno is local to you and he knows his stuff, uses a Mustang, and is someone I can vouch for.
JB
Old Jul 20, 2007 | 09:47 PM
LoRo's Avatar
Thanks John I'll give that a try. I sent you a PM BTW.
275
275
275
275
270
265
260
255
255
is what I have the boost limit set for now.
Ichigo0Soul
Mar 7, 2016 07:16 PM
ITRJake
May 23, 2015 12:34 PM
sirsleepsalot
Feb 7, 2015 12:04 PM
LeveeciusEVOIX
Aug 19, 2012 08:50 AM
BoosTyEVO
Oct 4, 2011 12:28 PM
