AFR Tuning - HELP
Old Jul 25, 2007 | 06:25 PM
tephra's Avatar
Question AFR Tuning - HELP
Hi Guys,
I did my first 3rd gear pull this morning with my WB02 connected - any comments:
Code:
LogSec	TPS	RPM	Timing	Speed	IPW	IDC	WB	Knock	Load2Byte
495.02	97	1968.75	17	34	5.888	9.7	14.5	0	100
495.20	100	2031.25	16	34	6.4	10.8	13.9	0	106.25
495.38	100	2125	16	34	6.656	11.8	13.4	0	111.875
495.55	100	2218.75	14	34	6.912	12.8	13.2	0	118.125
495.70	100	2281.25	14	38	7.168	13.6	13.1	0	123.125
495.88	100	2343.75	14	38	7.68	15.0	12.9	0	129.375
496.05	100	2437.5	11	38	7.936	16.1	13.0	0	137.8125
496.23	100	2531.25	11	38	8.704	18.4	13.1	0	149.0625
496.41	100	2656.25	9	44	9.728	21.5	13.0	0	161.875
496.56	100	2781.25	6	44	11.008	25.5	12.6	0	175.625
496.73	100	2875	5	44	12.288	29.4	12.5	0	197.1875
496.89	100	3000	3	44	14.592	36.5	12.5	0	218.4375
497.06	100	3125	0	54	15.872	41.3	12.7	0	241.25
497.23	100	3281.25	2	54	16.384	44.8	12.8	0	221.25
497.41	100	3437.5	3	54	15.616	44.7	12.7	2	219.375
497.56	100	3562.5	4	54	15.616	46.4	12.7	2	218.75
497.78	100	3718.75	5	62	16.128	50.0	12.5	2	226.25
497.95	100	3906.25	6	62	16.384	53.3	12.1	1	215.3125
498.14	100	4093.75	5	62	16.384	55.9	12.0	1	213.4375
498.31	100	4250	5	62	15.872	56.2	11.8	1	219.375
498.50	100	4406.25	5	74	15.872	58.3	11.8	1	213.4375
498.67	100	4562.5	5	74	15.616	59.4	11.8	0	218.75
498.83	100	4718.75	7	74	16.128	63.4	11.7	2	214.0625
499.00	100	4812.5	6	74	15.872	63.7	11.6	2	216.5625
499.17	100	4968.75	7	86	15.616	64.7	11.7	2	212.8125
499.34	100	5093.75	8	86	15.616	66.3	11.8	2	212.1875
499.50	100	5250	7	86	15.872	69.4	11.7	1	210.625
499.67	100	5406.25	8	86	15.872	71.5	11.4	1	210.9375
499.84	100	5531.25	8	96	16.384	75.5	11.4	1	213.125
500.02	100	5656.25	8	96	16.128	76.0	11.1	1	210.3125
500.17	100	5812.5	9	96	16.384	79.4	11.0	1	210.3125
500.36	100	5906.25	10	96	16.384	80.6	11.0	0	209.375
500.53	100	6062.5	12	106	15.872	80.2	11.0	2	206.25
500.70	100	6187.5	12	106	15.872	81.8	11.1	2	205
500.89	100	6312.5	11	106	15.616	82.1	11.0	2	204.375
501.06	100	6437.5	12	106	15.616	83.8	11.1	1	205.3125
501.23	100	6593.75	12	118	15.872	87.2	11.1	1	203.4375
501.41	100	6687.5	12	118	15.616	87.0	10.9	1	202.5
501.58	100	6812.5	14	118	15.616	88.7	10.8	1	202.5
501.73	100	6937.5	12	118	17.152	99.2	10.8	1	202.5
501.91	100	7031.25	14	118	16.64	97.5	10.4	0	201.5625
502.06	100	7125	14	124	16.64	98.8	10.4	0	198.75
502.23	100	7250	15	124	16.384	99.0	10.4	0	197.8125
502.41	30	7281.25	28	124	0.768	4.7	10.4	0	16.875
Personally I think it looks pretty lean up until 5500rpm... Is it worthwhile adding fuel from 3000-4000 rpm to get down to 12.0
mods: stock maps, 3" exhaust, EBC (19.5 PSI)
Cheers
David
Old Jul 25, 2007 | 06:41 PM
mchuang's Avatar
Personally I drop into the high 11's by 3500rpms, but before that I try to hit 12.1
Old Jul 25, 2007 | 06:43 PM
TTP Engineering's Avatar
Too lean at peak torque, too rich on top.
Old Jul 25, 2007 | 06:50 PM
alan678's Avatar
looking at your load cells....isnt that a bit low? At 22lbs i am around the 240-250 load cells using both Evoscan & Mitsulogger...maybe these values seem skewed because he isnt at peak boost ...
tephra's Avatar
yep, thats what I thought, 2 quick questions:
1) are those numbers about what you would expect for an IX (with lean spool enabled) - I want to make sure the WBO2 is working properly
2) if I am not knocking at those lean rpm's is there any point in richening it up? I thought leaner was better... (up to a point..)
edit: I should mention i'm running about 19.5 PSI boost..
cheers
d.
Old Jul 25, 2007 | 06:54 PM
alan678's Avatar
Well on my car i have an AFR of 11.8 during peak tq going to 11.2 till redline on 91 oct ...
also on 111oct i run 12.0 till redline...
Old Jul 25, 2007 | 06:56 PM
alan678's Avatar
can you take a snapshot of your timing/fuel maps for us to see where your timing is supposed to be versus to where its at on the log...that can also help us analyze your log a bit better...
Old Jul 25, 2007 | 07:02 PM
tephra's Avatar
timing is stock - do you still need that?
Old Jul 25, 2007 | 07:12 PM
nothere's Avatar
I hope I don't start another wb war, but it does sound like different sensors will have different readings. thus, a reading is only as good as its consequences on your motor. (unless you do hundreds of readings on hundreds of cars to know where your readings lean.)
so that would imply you tune to what you can get away with and then back off a bit.
in your case you may or may not be on the edge of to something. the only way to know would be to go a bit farther to see what the impact is.
same would go for timing, once you have come to an understanding on your afr. then the process starts over as you tweak to see what works best.
however as pointed out in another thread, the consequences of a broad range of afr has a small impact on power. it is conceivable you could run any where from 11.0 to 11.7 and not gain enough power to notice it.(say a few hp). it becomes a matter of efficiency to the obsessed tuner to tune afr to the tenth.
still in order to know where you stand with your motor and your sensor it might be worth it to find the limit so you can back away from it. not something I would advise anyone with the knock filter mucked with.
one last bit, I would try not to go wot until you are closer to 3k. unless that is your normal driving style.
Old Jul 25, 2007 | 08:54 PM
alan678's Avatar
Wouldnt hurt to post....i have an Evo VIII so i am sure the timing is a bit different...
Old Jul 25, 2007 | 09:03 PM
tephra's Avatar
ok but because its an IX I need to post all 3 timing maps, because its going to interpolate between 1/2 and 2/3 depending on conditions..
Old Jul 25, 2007 | 11:24 PM
burgers22's Avatar
Keep an eye on those IDCs as well, especially if you start running more boost up top.
MB
Old Jul 26, 2007 | 12:17 AM
Evo_Pma's Avatar
+1
Old Jul 26, 2007 | 04:07 AM
tephra's Avatar
yup I noticed the IDC's, not sure how accurate that is... injector scaling might be off..
you guys say too lean, but if its NOT knocking then is there any point in adding fuel?
Old Jul 26, 2007 | 05:01 AM
C6C6CH3vo's Avatar
Right at 7000 rpm it gets real rich, even though the counts weren't high it was the duration that perhaps sent it to low octane map.
Also, doesn't look lean to me anywhere maybe a little to much time, but thats just me. The lean part is where your making the power, from 3500 - 5500rpm it takes 2.18 sec, but from 4000 -6000rpm your already down to 2.41 sec too rich and too much time up top
On the other hand, for only 19psi the car looks pretty danm strong if you ax me. What kind of fuel was that?
