Looking at my logs with ECU flash
i'm still new to logging with ECU flash. As i was looking at some logs I checked out stationary rev limit and it says 0? I know its set at 6250(according to Sean Ivey). I also checked out the high octane fuel maps and across the whole map its -1 on each cell? Please explain
So that being said, when I click on the Stationary Rev limiter a small box will pop up showing as 0. I can't even change the value for some reason. Is there something that I'm not doing?
I'm not sure of this, but does the '03 ECU even support the stationary rev limit value since this wasn't a feature from the factory?
Also, if the ECU can support it... is it possible that it's greyed out because the ECU definition for ECUFlash assumes the '03 ECU doesn't support it?
Sorry to answer your question with more questions.
Actually, the 03 rom does support it (I'm using it on my car)
What definition the the rom claim it was when it was downloaded? Many times an improper or incomplete definition will be the reason you cannot view something.
Also, some tuners intentionally alter the ECUID so people cannot casually look at the tune or some of its settings without already knowing the ECUID that they started with (your stock Rom's ID), so thats another possibility. Though its pretty rare for a tuner to do that these days.
Jdubya
Aug 13, 2013 04:46 AM
