Tuning with Evoscan
Old Aug 19, 2007 | 07:41 AM
Jorge T's Avatar
These are the settings for creating a LW chart with load in 20% increments and RPM in 500 rpm increments.
If you want to see load in 10% increments add 31 as the number of steps in the horizontal axis and 33 in the vertical axis to see rpm in 250 increments.
Old Aug 26, 2007 | 10:02 AM
nj1266's Avatar
Originally Posted by kreionic
Awsome thank NJ. One last thing. I didn't see the jdm map in that file. I thought you used that too? If its not a hassle could you add that in there aswell. Thanks
This is an updated template. It has a PSI column. I have the columns arganized the same way as they appear in my Evoscan version 0.99. This way I copy the whole section of data from Evoscan and post it in the template. Then you can follow the same directions that I posted before.
File Type: zip
My_LW_Template.zip (752 Bytes, 28 views)
Old Aug 26, 2007 | 06:34 PM
kreionic's Avatar
NJ, The second template you posted doesn't work for me. The first one you posted on the previous page works fine. When I open the file with logworks after saving it with .log nothing reads right. a/f stays at 7.35 etc.. everything stays at the minimums that you put
Old Aug 26, 2007 | 08:21 PM
nj1266's Avatar
You must remove columns that you do not use from the template. If you leave empty columns then Logworks gets confused.
Old Aug 27, 2007 | 04:15 PM
kreionic's Avatar
Gotcha thanks
Old Aug 29, 2007 | 06:03 PM
kreionic's Avatar
Last thing NJ. When you remove the columns. ARe you also talking about the formula at the top? And do I need to change the names from lm1 to lc1?
Old Aug 29, 2007 | 07:58 PM
nj1266's Avatar
Yes remove the formula as well. That is what worked for me. You have try the LC1 to LM1 change and see if it works for you.
Old Aug 30, 2007 | 04:03 PM
kreionic's Avatar
This is odd. No matter what I do I can not get the second file you poosted to work. The first one you made without psi, etc.. works fine with no issues? I dont get it
NS@AEM
30
Mar 24, 2015 07:53 PM
BellyD
Northwest Region
126
Feb 8, 2012 01:49 PM
dyezak
66
May 14, 2010 11:36 AM
nj1266
Jan 17, 2008 08:08 AM
