gm solenoid strange boost?
Old Aug 27, 2007 | 08:56 PM
accident's Avatar
I still can't seem to get this thing figured out or maybe this is just the way this setup is. I added the new definations to my rom from Mrfreds recent boost post hoping that would help but it still seems to behave the same. I'm trying to acheive 27psi tapering to about 23-24ish.
Here is the deal, I can get it to hit 27psi as long as I start in 3rd gear. but when ever I start a WOT run from 1st and up all the way through 4th I can only hit about 24.5 psi. I have tried multiple changes to the MWGDC tables, TBEC tables, etc.. about the only thing I have going right is my BDEL+offset match my 2-byte load. About the only thing I haven't tried is the lean spool disable (I kinda figured that the mitsu engineers put this in for a reason )
I have increased my MWGDC table alot from when I switched from 91 to E85 and it just doens't make much of a difference in a 1st and up pull
Hopefully more of you guys out there have got the hang of this solenoid and can chime in. Any help would be greatly appricated.
thanks,
ed
Old Aug 27, 2007 | 10:22 PM
UCB's Avatar
UCB
edit: just read your post over again, OOPSS
1) You wont see 27psi in first
2) If you are going 1-4, that means you wont ever really see below 5k in 2nd-4th, by that time you are out of the peak torque range, and thus wont ever see 27psi (maybe in second with the wastegate shut )
good luck hitting 24psi at redline, even the GM solenoid cant beat the physics behind our turbo
Old Aug 28, 2007 | 04:11 AM
LoRo's Avatar
+1 but I have to ask the question WHY a GM solenoid?
Old Aug 28, 2007 | 07:16 AM
Mr. Evo IX's Avatar
The GM 3port is more responsive and allows the tuner more "headroom" to properly tune the boost tables for flatter boost accross rpm range as well as being able to run more boost than the stock system. The GM 3port with a resistor is a compatible replacement for the stock 2 port boost control solenoid.
Old Aug 28, 2007 | 09:49 AM
UCB's Avatar
UCB
Question
I guess you havn't been reading in here lately. The GM 3-port is widely used on many many factory FI cars
Old Aug 28, 2007 | 10:01 AM
DanInPA's Avatar
I am not sure what turbo you are using but hitting 27 PSI in 5K would be difficult. I would just set 100% MWGDC and see if it can hit it (I would also put 280ish all over the BDEL for testing purpose -- 280 - BOffset = number you want to set in BDEL)... That would be the max any way. Before you try it, make sure to put correction in so that it reduce WGDC if it does go up beyond your target...
27PSI is about 280ish load... Are you really hitting this load? 24.5 is about 264 load. I don't see TURBO upgrade in your sig... That seems way too much boost in my opinion even if you had ALKY kit in there for safety margin....
Old Aug 28, 2007 | 10:29 AM
accident's Avatar
I'm still on the stock turbo. I actually hit about 310 load tapering to about 250ish by redline. It is on E85 and barely get any knock when I do my WOT runs.
ed
Old Aug 28, 2007 | 10:34 AM
UCB's Avatar
UCB
ok..none of that means anything when you are trying to hit 27psi in a 1-4gear pull.
There are some things you can change about our cars, the turbos efficiency range is not one of them
Old Aug 28, 2007 | 10:43 AM
accident's Avatar
so basicaly what my car is doing is normal? so the only time I will hit peak boost is on a 3rd or 4th gear pull? this just doesn't seem right so basicly when drag racing you would never hit max boost?
Old Aug 28, 2007 | 11:02 AM
recompile's Avatar
Um, 27psi on stock turbo/stock cams is not 280 load... at least not the 2 Byte that most people log.
I spike 24psi and ~280 load, I hold above 270 load until about 5000RPM when it tapers... ~230 load at redline.
People running high octane and/or meth will run 27-28 psi at be over 300 load
Old Aug 28, 2007 | 11:09 AM
UCB's Avatar
UCB
Yes..you will only see those loads/boost levels below 4500rpm or so, and in 3rd, 4th, or 5th gear
You likely wont ever see 27psi in 1st or 2nd, and not above 5k in any other gear. So yes, for drag racing, its possible to never hit peak boost.
Old Aug 28, 2007 | 11:34 AM
DanInPA's Avatar
Thanks for sharing... That is a difference from one who has experience versus using a simple math (I'm a n00b : ) )...
I only used Load to PSI conversion (X-Baro)*0.145 = PSI. So, X being load would be x (Load) = PSI/0.145 - Baro.. I used 100 for Baro as an estimate...
But, it's good to know that only high OCTANE can see the load...
I used this method on my MR for tuning boost (2 byte load) for 93 OCT and was very close to where it wants to be.... (Used it to set the BDEL)...
Old Aug 28, 2007 | 04:07 PM
RazorLab's Avatar
100% with a GM solenoid would be a bad idea. It would severely overboost.
Old Sep 27, 2007 | 03:17 AM
al\lupo's Avatar
Just a question... is it safe for stock turbo such a load? I'm asking because I'm hitting 290 load (2 byte) with #60 pill (I leaved the restrictor on solenoid), stock cams/turbo, exaust and 255 fuel pump...
Old Sep 27, 2007 | 11:10 AM
recompile's Avatar
290 load is about 26psi on the stock turbo.
I'd suggest a couple things... first, a JDM MAP sensor. This will allow precise boost logging, as well as give you the option to use mrfred's true EBC (ie., you dial in a boost level and the JDM MAP reports back to ECU)
Using pump gas only, 26psi is pushing it... I was able to spike 26-27psi on pump with no knock, but honestly I'd rather not run more than 25psi on stock internals with only pump gas.
