Problem starting 1.29 ecuflash
Old Aug 31, 2007 | 11:53 PM
PeteyTurbo's Avatar
I was making the changes to log 2 byte rpm, load, and airflow and everything went fine until I added the airflow to 04 and 05 in the mut table..I am pretty sure I did everything right, but when I went to open ecuflash again it does not open and I get a message that says this:
xmlhandlerhelper:
Parse error at line 123, column 304:
unexpected character
Any ideas??
I put the 96940011 back into the evo folder that I had backed up but it did not change anything
Old Sep 1, 2007 | 12:03 AM
tephra's Avatar
post up your xml file (just the new bits)
Old Sep 1, 2007 | 12:06 AM
PeteyTurbo's Avatar
I deleted my modified xml, this is the one I am using in 96940011..
<rom>
<romid>
<xmlid>96940011</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>96940011</internalidhex>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>EVO8</submodel>
<transmission>Manual</transmission>
<year>2005</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
<include>evo7base</include>
<table name="High Octane Fuel Map" address="2abd">
<table name="Load" address="5c88" elements="18"/>
<table name="RPM" address="5c60" elements="15"/>
</table>
<table name="Low Octane Fuel Map" address="2bd7">
</table>
<table name="High Octane Ignition Map 1" address="30ad">
<table name="Load" address="5ce8" elements="19"/>
<table name="RPM" address="5cb6" elements="20"/>
</table>
<table name="Low Octane Ignition Map 1" address="3235">
</table>
<table name="Injector Battery Voltage Latency Compensation" address="2e98">
<table name="Battery Voltage" address="5bc8" elements="7"/>
</table>
<table name="Rev Limit" address="118c"/>
<table name="Stationary Rev Limit" address="2750"/>
<table name="Accel Enrichment" address="2f3c">
<table name="RPM" elements="15"/>
</table>
<table name="Boost Control Load Offset" address="1670"/>
<table name="Turbo Boost Error Correction" address="3b24">
<table name="Boost Error" address="5fd6" elements="17"/>
</table>
<table name="Boost Desired Engine Load # 1" address="3b84">
<table name="RPM" address="5fac" elements="16"/>
</table>
<table name="Boost Desired Engine Load # 2" address="3b9a">
</table>
<table name="Boost Desired Engine Load # 3" address="3bb6">
</table>
<table name="Max Wastegate Duty # 1" address="3b3c">
</table>
<table name="Max Wastegate Duty # 2" address="3b52">
</table>
<table name="Max Wastegate Duty # 3" address="3b6e">
</table>
<table name="Open Loop Load # 1" address="2d24">
<table name="RPM" address="596c" elements="16"/>
</table>
<table name="Open Loop Load # 2" address="2d3a">
</table>
<table name="Open Loop Throttle Low Load" address="2d56">
</table>
<table name="Open Loop Throttle High Load" address="2d6c">
</table>
<table name="IC Relay Timer Time" address="2090">
<table name="Condition"/>
</table>
<table name="IC Relay Timer Control Judgement" address="209e">
</table>
<table name="IC Relay Timer Air Temp" address="20a2"/>
<table name="IC Relay Timer ON Mode Switch Time" address="2084"/>
<table name="IC Relay Timer Control RPM" address="2086"/>
<table name="IC Relay Timer Control Water Temp" address="2088">
</table>
<table name="IC Relay Control Vehicle Speed" address="208c"/>
<table name="IC Relay Control EV" address="2082"/>
<table name="Desired ISCV intial step position with AC off-Neutral" address="393c">
<table name="Engine Temp" address="5e5e" elements="8"/>
</table>
<table name="Desired ISCV intial step position with AC off-Drive" address="3950">
</table>
<table name="Desired ISCV intial step position with AC on-Neutral" address="3964">
<table name="Engine Temp" address="5e78" elements="8"/>
</table>
<table name="Desired Idle RPM-Neutral" address="3920">
</table>
<table name="Desired Idle RPM-Drive" address="392e">
</table>
<table name="High Intake Air Temp ISCV Increase" address="1e14">
<table name="Condition" elements="2"/>
</table>
<table name="Boost Limit" address="2d14">
<table name="RPM" address="640e" elements="9"/>
</table>
<table name="Boost Enhancement (Anti-Lag) Start RPM" address="1280"/>
<table name="Desired Idle RPM with AC on" address="146c">
</table>
<table name="High Intake Air Temp Idle Speed Target" address="1e10">
</table>
<table name="Wastgate Solenoid Activation RPM" address="1668">
</table>
<table name="Speed Limit" address="118e">
</table>
<table name="Injector Scaling" address="1106"/>
<table name="Min Coolant Temp for Closed Loop" address="11aa"/>
<table name="Boost Cut Delay Timer" address="119a" scaling="Time"/>
<table name="Boost Desired Engine Load # 4" level="1">
<table name="RPM"/>
</table>
<table name="Max Wastegate Duty # 4" level="1">
<table name="RPM"/>
</table>
<table name="MAF Scaling" address="2a06" scaling="AirFlow8">
<table name="Load" address="5b78" elements="21"/>
</table>
<table name="MAF Smoothing Table" address="2a22">
</table>
<table name="Air Temperature Compensation" address="2a3e" scaling="uint8">
<table name="Degrees" address="5e5e" elements="8"/>
</table>
<table name="Barometric Pressure Compensation" address="2a51">
<table name="Atmosphere Pressure" address="5b66" elements="4"/>
<table name="RPM" address="5bac" elements="9"/>
</table>
<table name="Idle Stepper Look-up Table" address="3a35">
<table name="Throttle Position" address="5ee2" elements="8"/>
<table name="RPM" address="5efc" elements="27"/>
</table>
<table name="Knock Sensor Filter Map 1" address="3e69">
<table name="TAR" address="60b4" elements="12"/>
<table name="RPM" address="6094" elements="11"/>
</table>
<table name="Knock Sensor Filter Map 2" address="3f25">
</table>
<table name="Knock Sensor Filter Map 3" address="3fe1">
</table>
<table name="Knock Sensor Filter Map 4" address="409d">
</table>
<table name="Knock Sensor Filter Map 5" address="4159">
</table>
<table name="Knock Sensor Filter Map 6" address="4215">
</table>
<table name="Knock Sensor Filter Map 7" address="451f">
</table>
<table name="Knock Sensor Filter Map 8" address="45db">
</table>
<table name="Knock Sensor Filter Map 9" address="4697">
</table>
<table name="Knock Sensor Filter Map 10" address="4753">
</table>
<table name="Knock Sensor Filter Map 11" address="480f">
</table>
<table name="Knock Sensor Filter Map 12" address="48cb">
</table>
<table name="MAF Sensor Filtering" address="1108">
<table name="Load"/>
</table>
<table name="MAF Size" address="110c"/>
<table name="Boost Enhancement Enrich/Enlean (Anti-lag) Map" address="36cd">
<table name="Load" address="5ce8"/>
<table name="RPM" address="5cb6"/>
</table>
<table name="Boost Enhancement Adv/Ret Map 1 (Anti-lag)" address="33bd">
</table>
<table name="Boost Enhancement Adv/Ret Map 2 (Anti-lag)" address="3545">
</table>
<table name="Min Temp for Full Boost Control" address="1e06"/>
<table name="Boost Enhancement (Anti-lag) Stop RPM" address="1282"/>
<table name="Boost Enhancement (Anti-lag) Table" address="308e">
<table name="RPM" address="5c48"/>
</table>
</rom>
Old Sep 1, 2007 | 10:02 AM
PeteyTurbo's Avatar
anyone else encounter this problem? where can i download 1.29 again?
Old Sep 1, 2007 | 04:15 PM
WhiteEvo05's Avatar
PM me your e-mail...I'll send you a copy of v1.29a
Old Sep 1, 2007 | 04:21 PM
codgi's Avatar
Did you change the evo7base by any chance?
Old Sep 2, 2007 | 06:49 PM
PeteyTurbo's Avatar
I did not see anything out of the ordinary on the evo7base, and I don't think I have even ever opened that file before..I still can't figure out what went wrong..
Old Sep 3, 2007 | 02:08 AM
PeteyTurbo's Avatar
Well, It just dawned on me that the only thing I did before I started getting this error was change the COLOR of the maps..I was reading and found this to be a no no on the version 1.30..Could this be my problem and if it is are there any ways of restoring the default color scheme??
tephra
Apr 22, 2026 11:03 AM
redSLed
Jan 2, 2018 12:04 PM
Fast_Freddie
Sep 13, 2009 04:40 PM
nj1266
Feb 6, 2007 01:38 AM
dxbtune
11
Sep 8, 2006 03:08 PM
