evoscan
Old Sep 4, 2007 | 07:25 PM
1 WICKED EVO's Avatar
evoscan
can you use it to tune with out buying a wideband if so how do you know what your fuel is doing. my fuel trim never changes. my low is 100% mid is 78.9% and high is 50%. and the ecu load only goes to 160 max
Old Sep 4, 2007 | 07:29 PM
jrsimon27's Avatar
you need a wideband, tuning without one is like being a blind man
Old Sep 4, 2007 | 07:54 PM
ok thanks.
Old Sep 4, 2007 | 09:04 PM
Pd1's Avatar
Pd1
While you do need a wideband to tune your WOT AFR, you can certainly dial in your fuel trims without one (mid and high should both be close to 100 in EvoScan). Do a search on here and you'll find step by step instructions on dialing them in. Good luck.
