help with evo 8 lean spool disable?
Old Sep 7, 2007 | 06:50 PM
Evo442's Avatar
I've searched but have not found a good "lean spool disable for evo8's for dummies" - can someone help me out??
Old Sep 8, 2007 | 10:08 AM
JohnBradley's Avatar
Its the same as the IX, there are notes in there for doing the VIII as well. The only thing that matters is what year it is. 03-04 are 1681 and 1685, whereas the 05 is 1281/1285 like the IX.
Old Sep 8, 2007 | 11:32 AM
KartaRailed's Avatar
so there is lean spool in the 8's. very interesting...
Old Sep 8, 2007 | 11:41 AM
Ph3n1x's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=261465
Same thing for 8's.
Old Sep 9, 2007 | 12:22 AM
mplspilot's Avatar
oups
Old Sep 9, 2007 | 07:02 AM
Evo442's Avatar
awesome. thanks all.
Old Apr 9, 2009 | 04:27 AM
EVO8LTW's Avatar
I'm a little confused about what addresses to use in the xml file for disabling lean spool on my 04 Evo 8 (ROM 96420008). I've seen 1681/1685 like in the above post, but I've also seen 1680/1684, as in the "dummies" thread, as follows:
Originally Posted by Pd1
OPTION 2
Here are the lean spool tables for the Evo 8 94170008:
<table name="Lean Spool Start RPM" category="Misc" address="1680" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="Lean Spool Stop RPM" category="Misc" address="1684" type="1D" level="1" scaling="RPMStatLimit"/>
Is the above code what I should be adding to my .xml file?
I guess even the "dummies" thread is above my head!
Thanks,
Rich
Old Apr 10, 2009 | 12:15 AM
todd6027's Avatar
in ecu periphery1 change 0009 to 0008
Old Apr 10, 2009 | 04:24 AM
EVO8LTW's Avatar
I'm always a few steps behind here, so I haven't learned enough about the periphery bit tables to add that to my xml with confidence. If someone can help me out with the old way, I'd appreciate it.
Old Apr 10, 2009 | 06:29 AM
sti.this's Avatar
the new version of ecuflash has all the periphery bits. mrfred's periphery thread This has some of the bits defined. Ive got my start/stop values the same as well as the periphery bit off.
tephra
Sep 23, 2017 02:47 PM
WRC-LVR
Oct 14, 2015 04:12 PM
jrainwater
May 16, 2014 02:45 PM
kubaolong
Sep 12, 2013 07:23 PM
racer135
Apr 27, 2013 04:49 AM
