Ecuflash version 1.32
Old Sep 15, 2007 | 12:20 AM
andenbre's Avatar
I have successfully run1.3,1.31.1.32 on my xp machine and my vista laptop with no problems. must be lucky
Old Sep 15, 2007 | 02:17 AM
tephra's Avatar
no problems here except the documented endian BS
Old Sep 15, 2007 | 04:25 AM
MalibuJack's Avatar
I've been testing it for some time on a vista laptop with no issues. I had alot of custom definitions that were impacted by the endian bug, but it took me about 20 minutes to fix a majority of them that turned up. The rest will turn up when I'm trying stuff and I'll fix them as they come.
Old Sep 15, 2007 | 07:12 AM
tephra's Avatar
AFAIK we can just change any little's to big's - sh705x is a big endian processor...
Old Sep 15, 2007 | 08:11 AM
Jorge T's Avatar
I'm running 1.31 with no problems, I used notepad search "little" and replace "big"to fix my evo7base xml.
There is another bug though...some tables appear greyed out even with user level set to developer. I fixed each one by clicking on edit map and changing user lever to advanced.
Old Sep 15, 2007 | 09:03 AM
Smogrunner's Avatar
Two days ago I was tinkering with my partial throttle timing table using 1.29 with no problems.
Later that night I visited OpenECU.org and downloaded 1.32 here: http://www.openecu.org/index.php?title=EcuFlash
Everything seemed to go fine. I can read my stored maps with no issues, BUT HAVE "NO VEHICLE INTERFACE." I'm ready to just reinstall 1.29, but maybe I can sort this out with some help...
Old Sep 15, 2007 | 10:31 AM
Smogrunner's Avatar
^^^ crap, now I can't even log with Evoscan, it is saying it is a USB/cable problem. But other usb storage device works fine from the same port. arrggh.
Old Sep 15, 2007 | 01:33 PM
MalibuJack's Avatar
Out of curiosity, is the cable your using a real tactrix cable? I figured I'd ask..
Sounds like your experiencing a driver problem, you need to uninstall the old driver package and re-install the drivers for whatever version, dont remember the name of the file, but its usually in a drivers directory in the ecuflash install directory.
Old Sep 15, 2007 | 01:43 PM
broddey's Avatar
Originally Posted by donour
Stuffit certainly does work. I'm using 10.0.1 (build 260). I just tried it again now.
If necessary I can post a .dmg.gz version for folks to grab, but standard tools should be sufficient...
d
EDIT: emailed you another package to try as well...
Thanks for the support donour, but for some reason ecuflash isn't supported on my hardware. I have OS X on a flower book g4.
I guess I'm doomed to smashing my head into the keyboard.
Smogrunner's Avatar
Yes, MJ, that sounds like it might be the problem. Thanks. Yes, it is a real Tactrix cable, but I've shared it so many times around the shop that it could have gotten accidently traded with a different one.
Old Sep 15, 2007 | 01:45 PM
broddey's Avatar
Hey MalibuJack, can you throw a computer tard a bone here and tell me why my mac just won't let me use ecuflash?
I keep getting these error messages that its not supported on my architecture.
OS X on a CRAPPER BOOK G4
Old Sep 15, 2007 | 06:48 PM
broddey's Avatar
bump for a helpless computer user
Old Sep 16, 2007 | 11:08 AM
Smogrunner's Avatar
Got my issue fixed. Thanks.
Old Sep 16, 2007 | 06:28 PM
IWANNAGOFAST's Avatar
can someone help me? i installed the drivers and installed mitsulogger and ecuflash. mitsulogger works perfectly but ecuflash wont let me read my current map. it says "error occured see log window"
Old Sep 16, 2007 | 08:42 PM
codgi's Avatar
^^ and what does the pane on the right say (log window)? Or is this where you found this error message?
