Ecuflash version 1.32
Old Sep 14, 2007 | 03:09 PM
nj1266's Avatar
http://www.openecu.org/index.php?title=EcuFlash
This is the newest version. Did anyone try it? Does it have the same bugs as 1.30 and 1.31. I feel like a luddite since I am still using 1.29a
Old Sep 14, 2007 | 03:12 PM
kreionic's Avatar
haha dude I am still using 1.29 aswell. Everyone reported issues with 1.30 and 1.31. So I just stuck with what worked
Old Sep 14, 2007 | 03:13 PM
EvoDan2004's Avatar
aaaaa
Old Sep 14, 2007 | 03:17 PM
MR Turco's Avatar
only changes for subarus
Old Sep 14, 2007 | 03:27 PM
nj1266's Avatar
I noticed that. So basically, version 1.32 still has the bugs in 1.30 and 1.31
Old Sep 14, 2007 | 03:28 PM
broddey's Avatar
Anybody know how to open ecuflash for mac or what unzip tool to use? Stuffit expander doenst work
Old Sep 14, 2007 | 04:54 PM
mrfred's Avatar
nj, I tried 1.30 and it wouldn't run on my computer now matter what I did. Does 1.31 have the same issue or other issues?
Old Sep 14, 2007 | 04:59 PM
mchuang's Avatar
I have 1.32 working on xp and it works fine. What you have to do is take the modified portion of your xml files and paste them to the definitions, old definitions will not work.
Old Sep 14, 2007 | 05:25 PM
nj1266's Avatar
I had the same problem with 1.30 on my laptop. I have not tried 1.31, but people have reported inability to display the tables properly. The number were off, IIRC.
Old Sep 14, 2007 | 06:35 PM
mchuang's Avatar
There was an endian fix so therefore the old xml files will not work.
added Mac OSX (intel) support! - still some minor Qt issues on the mac...
moved to Q 4.3.0
2D and 3D graphing features working
task pane is hideable and has resizing splitter
significant improvements to the Subaru ECU defintions thanks to merchgod
add better visibility options for invalid or higher user level tables
faster on-demand XML parsing
add relative directory support in the options
read only support for H8/539 based mitsubishis - flashing disabled due to lockout problem
switch to true kwp2000 protocol stack for Subarus
fix endian reversal in metadata parser - old metadata files are no longer compatible! add shbootmode for SH705x processor recovery
fix asymmetry error in substeps for undo and redo. undo now does steps in exact reverse order, in case two or more substeps operate on the same data (as happens in a 2D interpolation)
fix crash on editing of static values
automatically detect and warn if Subarus are not in the test mode when flashing
Old Sep 14, 2007 | 06:38 PM
Evo_Jay's Avatar
Yeah, 1.30 has never given me any trouble
Old Sep 14, 2007 | 06:57 PM
Murf's Avatar
running 1.32 with 2 byte load mod no problems.
Old Sep 14, 2007 | 07:50 PM
Asmodeus6's Avatar
Is the table bug the fact that only a small piece shows?
Because I have 1.32 and view/graph doesn't work.
Old Sep 14, 2007 | 08:02 PM
donour's Avatar
Stuffit certainly does work. I'm using 10.0.1 (build 260). I just tried it again now.
If necessary I can post a .dmg.gz version for folks to grab, but standard tools should be sufficient...
d
EDIT: emailed you another package to try as well...
Old Sep 14, 2007 | 09:26 PM
codgi's Avatar
Unless you made changes to the base xml files, or added something to your rom file that indicated endian you shouldn't have had to do this. 1.31<->1.3 compare for regular rom xml files in windiff was the same for me.
That being said I haven't upgraded to 1.32 because its just a change for Subie's....
