Timing pulled in different ACD modes
Old Sep 21, 2007 | 09:32 AM
Paul Nelson's Avatar
Originally Posted by oldevodude
Anyone else notice that when the acd is changed from Tarmac mode to either snow or gravel that timing gets pulled? It was raining here a little today so I thought I would try to see how the car responded in a different acd mode and I was also logging with EvoScan. When I looked at a third gear pull I was surprised to discover that my timing was like 4-5 pretty much accross the rpm range. After a few minutes (and a few WTF's) it dawned on me that maybe the ACD mode in Gravel was telling the ECU to pull timing for lower likelihood of losing traction or some other unknown reason. I put the ACD selector back in tarmac mode and logged steady state throttle and changed ACD modes and the next log proved my thoughts correct. Although I have not spent a lot of time on this it looks like both gravel and snow pull the same amount of timing and the change happens "on the fly" because I started in tarmac then went to gravel and snow and back to tarmac and could clearly see my timing correspond to the correct cells after switching back to Tarmac. Maybe someone else could verify to make sure I am not crazy in what I experienced.
Anyway someone who is into it or one of the developers might be able to look into this further I could see where it might be beneficial to push a button and alter timing without having to reflash but I also realize the ACD parameters change.
PS Maybe this is old news I didn't bother searching or anything
Hmm never seen timing pulled with the AEM in all of our logs. Even with stock ecu. My guess is that you have knock and the ecu is pulling timing.
Old Sep 21, 2007 | 09:45 AM
topnitroracer's Avatar
Do you have all 3 high octane ignition maps the same or do you just have the changes in map 2?
Old Sep 21, 2007 | 11:22 AM
dudical26's Avatar
I thought it was confirmed that the ACD is TOTALLY separate from the stock ECU and that the two systems don't talk to each other at all??
Old Sep 21, 2007 | 04:42 PM
SoCalRedLine's Avatar
this sounds wierd to me... i will log this tomorrow and post logs.
Old Sep 21, 2007 | 06:57 PM
oldevodude's Avatar
I guess you missed the part where I said I was steady state throttle and performed logging under light load conditions to test. This was and is not meant to be a help me cuz im a noob thread in so much as I simply wanted to share what happens or happened with MY car when I push the ACD selector and change from Tarmac to gravel and Snow.
I loaned my laptop to my boss and he will be leaving for Vegas. I have logs to prove there is NO Knock and tps indicates part/light throttle and RPM was around 2500-3200 range where typically ignition mapping (all three maps) timing is way over 20.
Old Sep 21, 2007 | 06:59 PM
oldevodude's Avatar
All three maps are the same and I briefly checked them to make sure my load to timing indicated in cell was not the steady sate 4-5 indicated in log. this was part of troubleshooting process before figuring out it might be ACD switch.
Old Sep 21, 2007 | 07:57 PM
oldevodude's Avatar
For kicks I looked at the wiring diagram in the factory manual and the AWD ECU pin 36 connects to pin 79 of the ECU this does NOT appear to be a common ground between them (red/yellow wire according to manual) besides pin 39 on the awd ecu connects to the TPS variable resistance out. This tells me the awd ecu is at minimum aware of throttle position and probably changes it's activity based on it's g sensor inputs along with throttle position. Most of you already know the AWD ecu works with abs system and can apply brakes to wheels on a individual basis according to the 4 seperate wires going to the ABS control unit. To me it makes sense that the AWD ECU work with Engine control as we know it controls center diff. and braking for sure.
PS for those that care and or have access this data was gathered using the 2006 Evo IX Service manual Volume 2 section 90-130. 90-122 is For NON-ABS equipped models. not applicable to my vehicle
Last edited by oldevodude; Sep 21, 2007 at 07:59 PM. Reason: typo and extra rambling :)
Old Sep 21, 2007 | 08:04 PM
Asmodeus6's Avatar
Is this possibly to do with the fact the ACD uses reduced clamping force in the other modes? Wouldn't it make sense to cut some power if under a reduced clamping load, and slower lockup scenario?
Theoretical of course. I have no evidence to prove one thing or another.
Old Dec 17, 2007 | 09:28 PM
benniboi08's Avatar
hey nice find! can someone also confirm if the gravel and snow mode lowers mileage per gallon? I am in central jersey and weather has been bad so im always on gravel or snow when its icy or snowing out. I have been getting 15-16 mpg my last two fills at the bp i've been to for years. I've always got 19-21 usually. Also, i might want to add the car is stock no mods, 12k miles, had brand new ultra-performance all season tires (potenza 960as) put on and it began to lose mileage like this bad. Any input would be greatly appreciated!
Old Feb 13, 2008 | 02:28 PM
inco9nito99's Avatar
Bumping up an old thread, but I also have noticed decreased gas mileage in gravel, worse in snow. Tarmac= best mpg.
Old Feb 13, 2008 | 09:00 PM
mrfred's Avatar
Hadn't noticed this thread before. There is one wire between the ECU and the ACD controller. I need to get to one of my other computers to see if the data path is from the ACD to the ECU or vise versa.
Old Feb 13, 2008 | 09:11 PM
mrfred's Avatar
ok, the Evo IX wiring diagram shows that information is going from the ACD controller to the ECU, so in theory it is possible that the ACD setting can affect engine performance. Now just need to sniff around to see exactly what's happening.
Old Feb 14, 2008 | 01:25 PM
Mellon Racing's Avatar
I had some racing to take care of the other day and the car was very inconsistent, I kept bogging the launch for some reason.
later I noticed I left it in snow mode from last weeks sleet...I don't know if it was related or not but I turned it back on tarmac and so far so good.
Old Feb 14, 2008 | 01:27 PM
MR Turco's Avatar
I wonder if those multiple tables for the same thing, ie timing, has something to do with it.
Old Feb 14, 2008 | 01:37 PM
RazorLab's Avatar
I've dynoed the same car with all 3 ACD modes, same power every pull, within pull-to-pull variance of course.
Of course that's going straight on the dyno without any tire slippage...
