Newbie Play Nice
Old Sep 26, 2007 | 04:11 PM
chaz517's Avatar
Newbie Play Nice
can some explain to me what LOAD is? and what TIMING is? everything i read seems so interesting, and i just wish i could understand what it all meant... thanks in advance
Old Sep 26, 2007 | 04:22 PM
andenbre's Avatar
load is complicated, the ecm uses air flow throttle position and a few other inputs to determine a percentage that is related to calculated manifold pressure. most engines idle in the 30% range while 100% is approximatly atmospheric pressure, 100%+ load would be positive realative pressure or boost created by a turbo/supercharger ect
timing refers to ignition advance.
Old Sep 26, 2007 | 06:49 PM
andenbre's Avatar
if you dont understand then start here
http://auto.howstuffworks.com/engine.htm
Old Sep 27, 2007 | 09:10 AM
roger smith's Avatar
Timing (or ignition advance) tells you when a sparkplug will fire in relation to top dead center (TDC).
0 timing = sparkplug fire when piston is at top dead center (the very top of the stroke)
positive timing = sparkplug fire before piston reaches top dead center
negative timing = sparkplug fire after piston reaches top dead center
Old Sep 27, 2007 | 11:30 AM
TouringBubble's Avatar
Geez guys ... there's nothing left for me to comment on now ...
+1 and +1 for posts 2 and 4 ... that's about it.
freshkid
Oct 1, 2015 09:27 AM
batty200
Jul 12, 2012 03:11 PM
EVOEMS
Sep 4, 2009 10:50 AM
philamthebest
Mitsubishi TC-SST Discussion
May 11, 2009 08:01 PM
